Question about RTO Mega Motion 3 Wheel Travel Pal Scooter
I have the Travel Pal plugged into the charger. The charger has a green light on for electricity being on but there is no light on where it shows it"s charging. And it's not charging.
  • 21 Answers
Have yoy checked that the battery is well pluged. meaning possitive with possitive and negative with negative. sometimes grasse is stock on the joints of electricity, so brush them with a metalic brush, that should solve the proble.
Posted on Jul 30, 2010
I need to get a replacement charger for a Travel Pal 3 wheel scooter and want to know where to purchase one?
find a mobility scooter supplier in the yellow pages /on line and get one from there
check but most chargers are generic for the voltage of the scooter
Oct 07, 2015 | Mega Motion 3-Wheel Travel Pal Mobility...
Green power. Light on charger.Charging light not on when plugged in to batteries
How old are the batteries? Have you ever had them load tested? also get the charger tested. If the batteries volts are too low, the auto charger will not work. You may need to go to your local service centre for help.
Mar 18, 2015 | Pride Travel Pro 3-Wheel Mobility Scooter
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
May 22, 2012 | Razor USA Razor Pocket Mod Electric...
My Mother had me pick up a Mega Motion 111 Travel PAL WITH LESS THAN 40 HOURS USAGE. However, it sat idle for a year and the batteries register stone red dead zero. Anyway, I followed the directions cover...
Sounds to me that all the right checks have been made...
Heres a tech Tip ,9/10 battery chargers cannot bring up a pair of dead battery's.In our case Larry thats whats happening here.There isnt enough power in the batterys to turn your charger on.
Here are some steps in testing your charger ..
1) Take the two batterys out of the scooter
2) Find your self a battery charger that you can set at a trickle charge ,this setting charges at a very low voltage
3) Trickle charge each battery to a least 50%
4) Install the batterys back into the scooter
5) Plug in your charger
Now in doing this your charger should kick on for a while ,dont worry if it shuts off .The batterys being bad is the reason for it shutting off ,we are just testing to see if your charger is working.
This should keep you out of the shop.good luck
Feb 06, 2011 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
Travel Pro Scooter charging problem. I plug in the charger there is no light indication on the charger when it is plugged into the scooter or when it is unplugged from the scooter. Batteries will not...
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
Jan 13, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
RTO Mega Motion 3 Wheel Travel Pal Scooter Logo
134 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
