Question about Sanyo Televison & Video
Sanyo tv DS19204 sound, no picture
I have a SANYO tv DS-19204. The front input works but the rear coax connection only plays the sound and it doesn't show the video. I've tried different coax cables, reseated the connections on the circuit board and blew off the dust and still no picture. What do I need to do to fix it?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 128 Answers
If this is lcd or a dlp this could be a lamp issue but if this si a plasma tv this could be one of the power supply boards
Posted on Jul 30, 2010
Hooking sayyo tv to directv
Not sure if I understand what is happening here but if set on channel 4 the connection for the direct TV would have to be to the coax fitting on the rear of the set.
For the audio/video inputs on the rear or side it would have to be the same ones coming out of the direct TV box to one of the same but inputs on the rear--Audio/video are one connection and coax for channel four is a different one.
Dec 22, 2012 | Televison & Video
My friend gave me a Sanyo TV Model DS25730 and I need to replace the fixture where cable connect.
If the tv has audio and video inputs why not use these instead of the coax input.That is,as long as you have an external tunerwith audio and video outputs.
Feb 27, 2011 | Sanyo DS24205 24" TV
Sanyo model #DS19204 cable connector broken
Redio shack, best buy,some time walmart has them.
Aug 25, 2009 | Sanyo DS13204 TV
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
DS19204 digital ready?
yes purchase a converter box
this will enable you convert from VA to RF
Dec 22, 2008 | Sanyo DS13204 TV
How to record from my Sanyo DTV to my Sony Recorder?
first have the video recorder connected to the tv correctly,either coax out, red.white,yellow out, componant out or hdmi.[ see on back of the unit & the tv which connection you used.input selector is also known as video/source/line in or aux, sometimes even game. if there no such button on your remote, scroll down from channel 2 and you should be in some aux input.have the dvd playing,then you should see the video when you get to the right input.
wg
Feb 17, 2008 | Sanyo DP26746 26 in. LCD Television
SANYO MODEL #DS13204, DS19204, DS25204
Do you have a user manual? Look for the instruction how to reset your tv. Try to plug your tv to other outlet, Chech the AC voltage if compatible to your tv. If dosnt work you need a repairman to fix it.
Jan 11, 2008 | Sanyo DS13204 TV
Sanyo TV has no picture or sound
better to take this tv to service shop,possibiliy defective or cracked tuner,broken pc board,cold or intermittent solder in power supply or in main board..
Dec 16, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
145 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
