Question about SuperMicro X7DAL-E Motherboard
SuperMicro X7DAL-E will not power up
Please HELP! I've tested PSU and already RMA'd board once. All I get is a weak "erk" when I try to power up the system.
X7DAL-E-O Dual LGA 771 board
2-Xeon 5410
4 GB Crucial FB PC2-5300 RAM
Apevia 600W "Dark Side" PSU
Tagan A+ Monolith Full Tower case
All components are brand new. Only fly in the ointment that I can think of unless somehow I missed a jumper is that the PSU only has one 8 pin 12V connector for CPUs (Required according to documentation). Board has 8 pin socket for CPUs and additional 4.pin 12V for PCIe slots but docs don't say it is required. If it is, where do I even find a PSU that has both?!?
Any advice is greatly appreciated!
Jack
  • 396 Answers
I am using the same board with a PC Power and Cooling 1 K Watt power supply which is a little high in price and no longer available. I have been using PC Power and Cooling since the 1980’s and have had few problems and they have always kept up with the latest power standards if not exceeding them. The replacement power supply has even more power.
However, you can find adapters to use 4 pin IDE drive Power connectors for the 4 and 8 pin power connectors. PC Power and Cooling and Cables To Go both sell them. That is the cheapest fix for you but I would also use the PCI-E auxiliary power connector.
Follow the links:
http://www.pcpower.com/products/accessories/power_supply/
http://search.cablestogo.com/?Ntt=8+pin+power+supply&N=0
http://www.cablestogo.com/product.asp?cat_id=925&sku=35522
Posted on Jan 22, 2010
I need new driver intel 5000x chipset driver download
Almost all of the drivers are at
http://www.supermicro.com/support/resources/resource_drivers.cfm
Red Hat and SuSe are there as well as Microsoft.
Debian LINUX is on their website.
Jan 26, 2014 | SuperMicro X7DAL-E Server Board...
I can't my bios update.
Hello visit the homepage here:
http://www.supermicro.com/products/motherboard/xeon1333/5000x/x7dal-e.cfm
For downloading the manual.
You will probably need adobe reader, to read the content.
Here is how you upgrade the bios:
http://www.supermicro.com/support/resources/results.aspx
Remember flashing the bios with a wrong one, WILL destroy the mainboard !!!!!!
Good luck
Jan 18, 2013 | SuperMicro X7DAL-E Motherboard
My supermicro x7dal-e motherboard restarts after shutdown can anybody solve my problem ??
Go into the BIOS settings under Boot Features.
Make sure
Resume On Modem Ring
Keyboard On Now Function
Watch Dog
are all disabled.
Now the most important one.
Power Loss Control
This setting allows you to decide how the system will react when power returns after an unexpected loss of power.
The options are Stay Off, Power On, and Last State
Make sure this setting is Stay OFF!!!
Jun 15, 2012 | SuperMicro X7DAL-E Server Board...
Supermicro x8sax memory bank issues
The X8SAX motherboard has 6 memory slots. Try booting with one memory stick in each slot to identify which memory bank (dimm slot) is giving you issues. If you are able to boot off of a good slot, check the BIOS version to make sure you have the latest installed (R 2.0b). It can be downloaded here: Super Micro Computer Inc Products Motherboards Xeon Boards X8SAX
If you are unable to get into the BIOS at all, check the warranty status and submit an RMA request to Supermicro:
http://www.supermicro.com/support/rma/
Mar 01, 2012 | SuperMicro Desktop Board - X8SAX...
I cant find how to upgrade bios on supermicro x7dal-e as all applications that are available on supermicro site are 32bit and i run on win7 64bit ultimate. I am updating as only 4gb out of 8gb are being...
Hello jahbgh,
go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Manual" you need.
Than you'll be able to "Download the Manual."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://www.supermicro.com/support/manuals/
Feb 22, 2011 | SuperMicro X7DAL-E Server Board...
The machine will only post to BIOS and boot with 1 CPU installed. If I put both CPUs in, it won't post. both slots works, since it WILL post with either one of the CPUs in either slot. Thanks!
The CPUs must be identical. Also, the memory scheme is interleaved, so you must install two modules at a time beginning with DIMM #1A, then DIMM #2A and so on.
Make sure that the BIOS is version R 2.1c (latest):
Super Micro Computer Inc Products Motherboards Xeon Boards X7DAL
Nov 02, 2010 | SuperMicro X7DAL-E Motherboard
Where do I get raid drivers for Supermicro x7dal-e+ MB
you can find the drivers you seek here...www.supermicro.com/support/Bios good luck!
Dec 18, 2009 | SuperMicro X7DAL-E Motherboard
Can i run vista on Supermicro X7DAL-E Dual LGA771
The easyest way to find out would be to download and run, Windows Vista Upgrade Advisor x32-bit. Open the link provided below;
http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx
Microsoft windows 7 is faster than Vista.
Windows 7 adviser click on the link; http://search.microsoft.com/results.aspx?mkt=en-US&q=Windows+7+adviser&FORM=MSSBCUS
Hope you find this helpful.
Cheers'!
Mike
Oct 23, 2009 | SuperMicro X7DAL-E Motherboard
X7dal-e pci express
The problem is not the board, it is the implementation and the limit of the PCI-e lanes in the CPU.
Solution, Do not use slot 4.
For add in cards use old PCI-X cards at 133MHz.
They are cheap used, 64 bit, and are 8 times faster than PCI.
Oct 29, 2008 | SuperMicro X7DAL-E Motherboard
SuperMicro X7DAL-E Motherboard Logo
583 people viewed this question
Top SuperMicro Computers & Internet Experts
Tony
David
David
Victorman
Victorman
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
