Question about Dell (E210882) Motherboard
On my Dell MOBO, E210882 I have two SATA HDs and would like to install a third SATA as I see there are two more SATA connectors. Is this doable?
    Sergeant:
  • 206 Answers
Sure you can do that...as long as you have enough sata power adapters instead of molex. If u dont, there are adapters that take molex to sata and you can get them cheap at a repair shop
Posted on Jul 30, 2010
What if the computer doesnt have DVD/CD or floppy device. missing
Any Dell motherboard has connectors so that both a 3.5" diskette-drive, and a EIDE/SATA CD/DVD drive can be connected.
Jul 31, 2010 | Dell (E210882) Motherboard
Dell Dimension 3000, splashed liquid from canned air, mobo fried?
The spray on the MB should not be a problem - unless it was plugged in when you did it. Yes, you should be able to put in a new Dell motherboard. As long as the processor is of the same class, the Dell license should work fine. However, you may need to download new drivers for the machine to run.
If you really want to check the power supply, I would suggest you buy a tester. They are fairly cheap: $10-50. You want to be sure that your board is getting the right power at the right places. 12 V to the fan is fine. However, 3.3 v or 1.5 v?
It sounds like you have done a fairly good test of the motherboard. I've definitely seen bad Dell motherboards with the light on with/without a bad power supply.
If you have another case (an ATX), I would buy an Asus or other motherboard and put your equipment in it. The cost of a Dell motherboard is excessive. Of course, you will have license problems with XP.
May 22, 2010 | Dell (E210882) Motherboard
Good day I want to use a sata hard disk and
you will need to put in your windows disc and press f8 or whatever you need to press to gain access to your bios settings once in set your pc to boot from cd not h/d it will begin set up for a new install and ask if you want to install a third party sata disk etc click yes at this and follow prompts, restart pc and change bios settings back to h/d detection should then work.
May 09, 2010 | Dell (E210882) Motherboard
Control panel connector pinout for Dell Dimension 1100
Well the official Dell manual can be found on their website here. I don't know if this helps or not, but I hope it does! :)
Feb 17, 2010 | Dell Computers & Internet
Does the E210882 MB have a sata port? Dell Dimension 3000 pentium 4, 3 G
No it doesn't. It has 2 IDE connectors.
Refer to: Dimension 3000 Specs
Thanks for using Fixya.
Nov 28, 2009 | Dell (E210882) Motherboard
Will dell motherboard support a sata 320gb hard
yes it will and make sure that your system has minimum of 1 gb ram ,this configuration will actually make your system run faster and in full throttle mode
so leave all your worries and upgrade to 320
kindly rate this solution
thanks and regards
Oct 31, 2009 | Dell (E210882) Motherboard
MOBO DEATH X-|
you might have shorted the board out if the computer was running and you didn't ground yourself out befoe touching anything antistatic wrist strap.
Dec 31, 2008 | Dell (E210882) Motherboard
Dell Motherboard E210882 Rev 00
My Dell has a SATA hard drive and the E210882 motherboard. Hope this helps.
Mar 14, 2008 | Dell (E210882) Motherboard
Dell Deminsion 2400
Typacally with a dell they have a prepritary mobo plate that slids into the case but if the mobo is directly screwed to the case and you can take the mobo connector panel off the case then yes you can. If the mobo is on the plate then more than likely no unless ya get the same mobo from ebay or the like :-(
Sep 15, 2007 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
89 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
