Question about Whirlpool Refrigerators
We recently bought a used Whirlpool, model ET8RHMXK005, with ice maker. Since we are using it for a second refrigerator in the garage, we did not hook up the ice maker. The refrigerator drips water down on the shelves. Can we do something about this. It seems to freeze ok. No melting or thawing in the freezer unit.
aborcass
  • 2651 Answers
SOURCE: Loud banging noise and water leaking
not much can be done about compressore noise, short of replacing it. but your drain issue is easily fixed, with that whirlpool heat strap you mentioned.it actually wraps around the heater in frezer section and the idea is that when the unit goes into a defrost cycle(3 or 4 times a day) the heater heats the strap(which runs into drain tube) up as well, preventing tube from freeezing up and eventually backing up into your freezer floor
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Model 78185891 type C21TFA95, water leakage problem
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
  • 1073 Answers
SOURCE: water drips in to the
check te defrost drain
Posted on May 06, 2008
  • 1073 Answers
SOURCE: Water inside the refrigerator
check for a door gasket problem on one of the doors if it is not sealeing all the way you will get moisture in the fresh foor section and additional forst in the freezer
Posted on Jun 10, 2008
  • 172 Answers
SOURCE: Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
Mca0824@aol.com
Posted on Oct 28, 2008
CAN I INSTALL GE ICE MAKER IM4 INTO MY whirlpool ed2chqxkq05
Very unlikely as they are driven by the logic board in the fridge.
Easier to fix the old one.
Aug 03, 2016 | GE Refrigerators
Remove ice maker whirlpool refrigerator
Ice maker repair - How to remove Whirlpool Kitchenaid ...
? 2:01
https://www.youtube.com/watch?v=UHi59JFB3N8
Feb 13, 2014 - Uploaded by AdamDIY
This ice maker is used in: Whirlpool, Kenmore, KitchenAid this one ... ... How to remove an ice maker from a ...
Jan 08, 2016 | Whirlpool Refrigerators
Ice Maker Not Producing Ice - No Power To Water Control Solenoid
Yes, most likely a defective ice maker, since we know the valve is passing water, once energized.
Dec 31, 2017 | Whirlpool Refrigerators
Remove ice maker?
Yes you can just remove the ice maker and no cover is necessary for the female connector, it will not harm the operation of the unit at all. You just need to use trays if you want ice.
Apr 19, 2014 | Whirlpool Refrigerators
Do you need Whirlpool model number? New fridge and my question is about ice maker. How to fill ice cube tray?
Here is the manual for your appliance: http://www.searspartsdirect.com/partsdirect/user-manuals/136708/GB2FHDXWB07-Whirlpool-Parts-REFRIGERATOR-manual?pathRender=fromManualTabPage
This model should refill the ice machine itself, as long as it is connected to a water supply. Page 12 tells you how to turn the ice maker on/of
Apr 10, 2014 | Whirlpool Refrigerators
Model TFX25PR ; Does the ice cube maker require any lubrication ?
The type ice makers made for your model and other models require no lubrication and are one of the most used parts of your refrigerator especially if there is a large family and lots of ice used daily. They never seem to stop working while the average refrigerator last 15 to 20 years the average life of an ice maker is only 5 years. Even ice makers that have replaceable parts the repair parts are more expensive in most cases than complete replacement. Below is an example of an average ice maker that Whirlpool and Maytag uses that have the Teflon coating in the ice slots. Your model is for GE,=> Model WR30X10093 Ice Maker and has electronic controls and no replaceable parts. Thanks, Sea Breeze
Jun 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
HI, I have a Whirlpool Side-By-Side Refrigerator model ED25PQXW01 and the ice maker isn't working, how do I fix it??
Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
