Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag commercial washer being used in single family residence (coin operation not needed). How do you set the timer for more than 5 minutes?
    President:
  • 3,773 Answers
Timer time cannot be changed
Posted on Jul 30, 2010
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
We have a maytag dryer that is coin operated in our home. We want to shut the coin operated part off. how do we do that?
remove change acceptor usually 5/16 stud bolt in timer mechanism, theb remove change slot stops and reinstalll mechanism and bolt then just push in and pull out just like if you would of used change but dont need two
Jan 31, 2011 | Maytag Coin Operated Stacked...
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need to reset price for washer and dryer
if its not working board might be bad
May 18, 2009 | Maytag Washing Machines
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Maytag commercial washing machines/dryers that use tokens. is it easy to convert these to accepting coins instead? how is this done?
push in slide coin acceptor,b48b65c.jpg requires different slide
multi coin single slot acceptor, ee120a2.jpgneeds new program
Oct 28, 2008 | Maytag Washing Machines
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Find a manual
The coin operator timer consists of several small plastic gears. The teeth on the last plastic gear gets all chewed up so that the timer continues to run and unable to open the circuit which stops the dryer timer. Although the plastic gear probably costs pennies, your will need to order part number 33001275 torsion timer for about $75 - $110. Remove one screw & 3 clip-on wires - 15 min.
Mar 06, 2008 | Maytag MDG16CS Gas Commercial Dryer
I need the coin programming instructions
what sort of coin acceptor is it? single slot? multiple coin slide in? write me at my email: srf12980@localnet.com.
Sep 12, 2007 | Maytag MDE16CS Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
195 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
