Question about Uniden Depth Sounders UNDQT206WHP ()
Need connections for the uniden qt-206 um200f to connect the wires to a airmar p79 tranducer
  • Uniden Master
  • 696 Answers
The P79 connects to the QT 206 as follows.
Red and black are side-by-side (red on the left) while the shield connects below the red. In case anyone requires it, here is the link to the QT 206 owners manual.
Hope this helpful
-Steve
http://www.uniden.com/pdf/QT206om.pdf
Posted on Mar 16, 2015
2 Suggested Answers
  • 64 Answers
SOURCE: Whta fluid do I put in a QT-206 transducer base wh...
You can use mineral oil, baby oil, I recommend the environmental friendly (pink) antifreeze.
Posted on Jun 14, 2010
I need to wire up the fuse box for 206 year2010
Thats not very difficult, locate the mounting bolts, remove the box and continue to removed the connecting wires.
Jul 21, 2016 | 2010 Peugeot 206 2.0
Will the speedo work on an Airmar ST850 with only the green wire connected
You'll need three wires connected.
The green is the signal from the ducer, the red provides power to the ducer and the bare wire is common ground. See the link I've provided for more info.
Hope this helps.
http://www.airmartechnology.com/uploads/wiringdiagrams/91_636.pdf
Mar 01, 2015 | Airmar Boating
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
What is the replacement transducer for uniden QT206
Just about any marine chandler should be able to source one of these for you. They're made by airmar who pretty much make all marine ducers now. Here is the link to just one place you can order it.
-Steve
Uniden Nylon Thru Hull Transducer For QT206 650 5406
Jan 20, 2013 | Uniden QT206 Transducers
My Fishfinder 300C suddeny does not detect the depht anymore, all oher function are still working, please help!
Hello
First do this. From the Home screen, Seelct Full Screen > Menu > range. Use ROCKER to set the depth scale, and see whether the depth is displayed or not. If not check the transducer for fault. Check for voltage goint to it.
Use a test light or voltmeter to determine the polarity of the voltage source.
Connect the red (+ or positive) wire to the positive voltage terminal.
If you use the fuse block on the boat, route the positive connection
through the fuse
Connect the black (- or ground) wire to the negative voltage terminal.
Install or check the 3A fuse (on the fuse block or in the in-line holder).
Align the notches on the cable plug and on the back of the Fishfinder 300C. Insert the cable into the connector, and turn the locking ring
counter-clockwise until it stops.
If htese all are correct and voltage is there at the tranducer end, the tranducer is faulty, and should be replaced. OK
Jul 25, 2011 | GPS
Whta fluid do I put in a QT-206 transducer base when mounting it inside a fibergalss hull ? I had heard baby oil ...
May 18, 2010 | Boating
Wiring problem
peugeot complicated their wiring alternately how old is the 206 if it is early then u need to connect both lives to permanent live on car if it is a late 206 then switch the lives
Oct 12, 2008 | Car Audio & Video
Unit showing 88.8 in the LCD window.
Hello geld1. Your problem is the transducer, cable or connector. Check transducer with an ohm meter, flex the cable while ohming the restance shouldn't change. The location and mounting of the transducer could be the main problem. Use the the correct gel film including a secure postion support.
Sep 22, 2008 | Uniden Qt206 Thru Hull, Digital Depth...
Uniden Depth Sounders UNDQT206WHP () Logo
242 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Mike Marcotte
Mike Marcotte
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Uniden Boating Expert? Answer questions, earn points and help others
