Question about Samsung RS2630SH Side by Side Refrigerator
My samsung side by side was working great untill
My samsung side by side is almost a year old. It was working great untill the fridge side quit cooling. It stayed at about 60 the frezzer was -10. Three weeks later the freezer quit cooling. I took the panal off the inside of the frezzer and found everything all frozen. I noticed that the fan wasn't working. When I unpluged it and pluged it back in the fan looked like it tried to start but didn't.
My question is could the fan be the problem or might it be something else?
Thanks Bill
MINE sAMSUNG DOESNT KEEP COLD THE FREEZER SIDE IS COLD BUT NOT TOTALLY FROZEN I DID SEE THE BACK WALL ICED UP. IT ALSO DOES'NT MAKE SOUNDS WHEN DOORS ARE OPEN. I REPLACED A FAN ON FREEZER SIDE BUT ITS STILL NOT WORKING. ITS ONLY 4 YEARS OLD. HELP
Posted on Aug 11, 2010
    President:
  • 3,773 Answers
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Posted on Jul 30, 2010
4 Suggested Answers
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
SOURCE: Samsung RS2534 Freezer works but fridge side isn't very cold
replace the sensor and the main board
Posted on Jun 07, 2009
We have a Samsung side by side and it just quit working. The only thing that is on is thr ice cube symbol that is flasing. The lights on the inside is also on. but nothing is runing
try unplugging count to 10 then plug back in, if this fix works you just rebooted the computer main control. located in back of fridge. then you will see 88 or something like this on display. this should be gone in 24 hrs. if not call samsung tell them what is display look like they should be able to tell you what is wrong
Sep 23, 2014 | Samsung Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
This is going to be a problem with either the thermostat control or the compressor relay from the freezer to frigde, either way, you will need to call a service tech.
Jul 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Have a 6 - 7 year old Samsung RS2534WW from Best Buy. The back interior wall of the fridge is bulging forward/inward for quite some time now. We had to remove some shelving in order to be able to close...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Samsung RS2534 Side by Side Refrigerator
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side not cold-freezer great
there is a three prong replay that hooks up to your compressor sounds like it needs to be replaced
Sep 01, 2008 | Refrigerators
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung RS2630SH Side by Side Refrigerator Logo
246 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
