Question about Briggs & Stratton Briggs and Stratton 030434 3250 Watt Portable Gasoline Generator
Remove motor from generator
My portable gas generator broke a piston rod and in turn cracked the block.How can I get the engine off of the generator anf replace the engine?
    New Friend:
Remove the long bolt that holds the armature to the crankshaft, Tap (thread) the hole in the armature as far down as your tap will reach, Use a long bolt or rod stock and a smaller rod as a spacer between the crank shaft and your rod stock ( cut to length) this is your homemade puller. as you tighten the rod stock, hit the sides of the armature with a wood block and (using a hammer against the wood) it will probably pop loose then.
Posted on Feb 09, 2013
Aramature must be removed to get to the mounting plate it will slide out off case loosen long bolt in center of armature hold armature and hit bolt briskley will pop off be careful putting arm back may be 2 brushes inside have a helper hold brushes back
Posted on Sep 13, 2010
First of all remove gas tank from frame then at the back of the generator you should see some bolt heads undo theses then engine should part from generator
Posted on Aug 01, 2010
Motor wont turn over
Your engine is physically ruined, most likely from a thrown rod, but could be a number of things. Time to get a rebuilt engine and hope they'll accept yours as a core. If you're knowledgeable, you can remove the engine, disassemble it, and find out what went wrong.
Mar 13, 2014 | 1994 Nissan Pickup
Keeps bending pushrods
It sounds like your tolerances on cams, etc, inside the engine are out of spec causing this problem. I would do a complete teardown of engine to properly diagnose.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Feb 10, 2014 | Eastern Tools & Equipment ETQ TG72K12 Gas...
My van motor just broke, i had just filled it up with gas, how can i get gas out of it
Remove all plugd and disable coil pack (for safety) and crank engine.
The pistons on all cyc. will push all gas + coolant out of the engine.
Please use towel /newspaper to protect the engine bay and floor before cracking the engine.
The oil/gas/coolant mix will make the floor.
Jul 30, 2011 | 1999 Plymouth Voyager
Xp8000e wont start. sound like a dead battery, nor will pull start turn engine over.
have you tried removing the spark plug and see if possibly there's a hydro lock from gas or oil in the piston area of the machine,this will remove any pressure off the starter and also pull rope mechanism,then you can visually look into the cylinder and see whats going on,then if this doesn't help then you may have a locked up engine from lack of oil lubrication and the rod bearings in the sump may be bad resulting in the need for a complete rebuild of the engine,if the engine checks out o.k. then you may have a locked up generator head,you may need to split the two components to find out which is locked up
Feb 03, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
My fg6000mk i think the rod cap that connects the rod to the crank has broke or just came off. i can remove the spark plug and the piston is at full stroke. i can take a small 12inch 1/4" extension and...
tear it down if indeed this happened i highly suggest you replace engine that will interchange with one that you can fix cheaper and easier the old engine with that damage will not be worth fixing hope this helps
Aug 30, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
My truck was stuck in a river. Took out plugs and got the water out of the motor. As i was trying to start it (it started to run rough a few times) when we heard a loud snap and the motor locked, we backed...
What you Have Described is Indicative of Throwing a ROD. Practically the ONLY thing this Can Be Is A Connecting rod Broke Loose and was Ejected Into the Oil PAN this Is FATAL Engine Damage.
To Fix it Without Replacing the Engine ? YES But Engine Must be removed and Disassembled to repair it and the COST Would Be Excessive.
Best Bet is Replace Engine, New Engines Have GOOD WARRENTEE"S --- Used Engines have SHORT Guaranties BUT With a SKILLED Technician Doing the Selecting for you along with Finding one With LOW MILLAGE then you get off Much Cheaper that NEW One. Hope This Helps and Sorry to Have BAD NEWS on Your Engine
Jun 03, 2009 | 1999 Ford F150 Regular Cab
Sounds like something broke in motor 1988 corsica 4 cylinder
If the sound is coming from the block, than it probably is. the rod broke from piston pin. Don't run motor if it is like this or the rod WILL go through the block.
If it is from the head, it may be a push rod.
Jun 02, 2009 | 1988 Chevrolet Corsica
Motor Blew Up
Normally they only have a 90 day warranty. But if the generator is under a year old I would contact the manufactor and see what they say.
Jan 04, 2009 | Coleman Powermate Powermate 5000W...
Briggs & Stratton Briggs and Stratton 030434 3250 Watt Portable Gasoline Generator Logo
963 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
