Question about LG Flatron L1750S 17" LCD Monitor
I have a dual display at work. one of my two displays is the LG Flatron L1750S. When I go to lunch my LG seems to go into some kind of power saving mode and the screen turns off, but the green light at the bottom will blink. My other monitor has no problems coming back on, but no matter what I do, the LG wont turn back on. It acts like it is on in terms of I can pull screens between the two monitors, but the display wont come on. I cant even turn the power off using the button, it just keeps blinking. I have unplugged the monitor and plugged it back in, only to have the same result. Usually I can log off of my computer and log back on and it will start working again, but not today. Any ideas what would cause this and how to fix it? I dont want to have to completely power off my computer everytime I come back from lunch just to get my second monitor to work. HELP!
  • 11,361 Answers
Monitor this gae will more likely to have bad DC filter caps: http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 01, 2010
LG Flatron L1753S very bright LCD display how do i remdy this please kindly thank you
You can adjust the brightness with the on screen display controls. This link will get you the manual.
May 02, 2011 | LG Flatron L1750S 17" LCD Monitor
LG Flatron screen out the writing power save mode and then only a black screen please give solution thankz
I have a power save problem, a capacitor causes it where can I found the capacitor on the power circuit?
Jan 20, 2011 | LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1750S will not come out of "power saving mode" any ideas on how I can fix this problem?
Try it with another PC first, if still not working, then start looking at the power supply DC filter caps first.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Aug 31, 2010 | LG Flatron L1750S 17" LCD Monitor
L1718S won't come on
hi
my dear LCD monitor dosn't have power saving mode it's from your CPU
may be you have problem with your Display setup from your CPU
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
Monitor cuts off
Hi...there,
In power saving mode to preventing futher damaged to the monitor. It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it... Happy Holidays!
Nov 11, 2008 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S LCD won't display anything...
To your concern, a couple of suggestions:
  • if you could try again a reputable electronics service center/shop, pls mention for them to look at the CCF (cold cathode florescent) lamps, the inverter and/or the main board;
  • the blinking light is significant, it could indicate loss of video signal or internal protection kicking in;
  • possibly heat related, check for any of the capacitors bulging or leaking.
If they would reference a service manual or a schematic diagram, pls relay that it is chassis CL-82 for an LG L1750S. Foremost to check would be for the presence of both the 12 and 5 volts,.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 22, 2008 | LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Power saver
This problem is showing when the main PCB of the monitor failed. Mr. Ravis not to worry you have warranty, contact the LG service provider in your area. They will change the PCB. check this link to get the service center info
http://www.lgservice.com/
Dec 23, 2007 | LG Flatron L1750S 17" LCD Monitor
Screen shutting down
Well, Gestion Alim is French for "Power Management." It means that your computer is shutting off power to the video using the ACPI power settings, probably stand-by or hibernation. Bring up the Power Management settings in your operating system (in Windows, it's the Display icon in the Control Panel) and change them to something more reasonable. If you want to disable them completely in Windows, change to "Presentation" and make sure that hard disks and display are both set to "Never" shut-off.
Nov 08, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron LCD Power Saving Mode
Well thats seems tricky does it not come on at all when you boot the computer. If the screen is working then it should work to display the Start up screen. If it does then keep pressing Delete until the BIOS comes up- then search the pages for power saving and slect to OFF
May 18, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
163 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
