Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Freezer is not freezing and - Kenmore 53092 / 53094 Side by Side Refrigerator
    President:
  • 1,099 Answers
The most common problem is the condenser under the refrigerator is clogged with lint. Pull the unit away from the wall for clearance,tip it rearward, and have someone use a vaccum on the dust. Unplug the unit while working on it and remove what can slide around be careful not to damage the works underneath, as dirt is the whole problem.................. Get it clean as you can and reset to factory settings and leave it alone for 24 hours.
The FACT THAT IT IS STILL FREEZING MEANS THE WORKS ARE OK.!
If it still doesn't work correctly, you need freon added by a service man, but I think cleaning is all you will need.
You might remove the back and clean behind the unit if needed
Also note that
First and simplest thing is to make sure your condenser coils on the back of the fridge usually, are clean and have adequate air circulation. If you pull the fridge away from the wall you can just brush them off or use the brush on your vacuum.
One thing I have seen is a frost-free fridge building up ice on the cooling coils, this happend to me once during a hot spell here, although DW may have put a pot in the fridge such that it blocked the door barely open, not certain.
What I do know is that shutting the fridge off completely and opening both doors for a couple of days let the ice melt, and then I re-started it, it worked fine and still does.
This is one of the situations where having a spare fridge or old fridge in the basement or garage comes in handy. Or a small dedicated chest freezer.
If you don't have and don't want to buy any of the above, get a really good ice chest, put the contents of the fridge in that, ideally just use up the stuff in the freezer.
One other thing is to buy a pair of fridge/freezer thermometers, put one in each chamber, measure the actual temperature. One measurement is worth 1000 guesses.
If the cooling coils are blocked with ice, you can expect a good bit of water when it melts, you will see a catch basin on the rear of the fridge near the compressor, be ready to remove some water from that using something like a turkey baster.
If the coils were iced up, and the problem recurs within a few weeks, probably your heater timer and/or heater are out. These are generally worth fixing.
Hope this helpout........
Posted on Jul 30, 2010
My kenmore upright freezer is running but not freezing is there a reset button
**Freezing gas may have leaked out at some point. Compressor works but freezer not freezing.
**Thermostat setting not suitable for freezing to occur; check and adjust
**Check whether evaporator at the back of your freezer is hot/slightly warm to touch. If it's not; call your freezer service/repair man asap
Oct 14, 2017 | Kenmore Computers & Internet
My freezer will not freeze or cool. I checked the compressor and us cool to the tough but the copper is very hot??? Help please
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Also, using a freezer to cool hot items or opening the freezer frequently will affect the... the freezer is running but not freezing is improperly packing the contents.
Fix a freezer not freezing but still cold - YouTube
? 1:34
www.youtube.com/watch?v=hCUewYVyiFQ
Aug 19, 2013 - Uploaded by Dave Here My freezer wasn't doing a good job freezing but there was ice on the back ... If not, approximately how often will I need to repeat the process?
Oct 19, 2015 | Refrigerators
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
Feb 10, 2015 | Whirlpool 10 cu. ft. / 283 liter Chest...
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrig not cooling but freezer is
The freezer door not closing properly would caused the freezer to freeze up
Feb 21, 2018 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Not freezing
check to see if your condenser is dirty, that can be the problem if looks clean, suspect low refrigerant charge
Mar 19, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer will not freeze except when using fast freeze
the electronic controller is faulty,make sure you have been supllied a freezer stat and not a refrigerator stat..
Nov 05, 2007 | Freezers
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
