Question about Mitsubishi WS-55511 55" Rear Projection Television
The tv was showing a double picture and the color was off. After I unplugged and plugged in again, it worked for a couple of days...now the power button doesnt stay on and it doesnt work at all...it is only 8 years old and I serviced it a few years ago...about 3yrs. ago for 700 dollars...did I get a lemon?Model #WS55511
  • 10,594 Answers
Double picture is common problem of rear projection tv that appears due to failure of convergence output ICs. These chips got bad because of heat and high amount of current consumption.
Your tv got convergence output ICs problem that will be replaced to fix the issue.
Let me know if you are handy with electronics stuff repair and can remove/ install parts in circuit board with soldering iron and want to repair tv by yourself in $100
If you are not comfortable with do it yourself then local tv repair shop will fix it for you and repair would cost you around #200 to $250
Thanks.
Posted on Jul 30, 2010
Every time I unplug my Panasonic or the power goes out my tv won't turn on for a couple days. Then it'll work till we unplug it again or the power goes out again
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Picture works on tv but not dvd only sond works
Should be one of 2 problems:
  • Connections in wrong spot - double-check to make sure all cables are in correct inputs and outputs
  • DVD may be set to display video through a digital conneciton instead of analog (or vice-versa)
If it's not the connections, then try unplugging the DVD player, hitting the power button couple of times, plugging it back in, this may force it back to default settings (if you're not using DVI or HDMI connection).
Apr 07, 2009 | JVC AV27MF47 27 inch TV
My TV is showing a double picture
If the picture looks like a 3D one, the problem is a convergence issue. This can be as simple as poor connections at the pins of the convergence ICs or defective ICs. If you can solder you can probably fix this yourself. Please note that there are potentially dangerous high voltages inside the set even when unplugged.
If you wish to attempt the repair, please update this and I will provide additional details and instructions.
Dan
Mar 02, 2009 | Toshiba 43HX71 43" Rear Projection...
My XBOX 360 has a Sound but no picture issue.
Well the main solution that you're going to get from Microsoft is to unplug everything from your console and your TV and then wait a couple minutes and plug it back in while everything is off. If the problem still persists, instead of buying a new 360, try borrowing a friend's AV cable and see if that works. Try not to unplug or replug anything while the console or TV is still on. Or it could just possibly be all of the jostling around in your suitcase and nothing has come loose enough to stop working until now. Sorry I can't be more helpful, these are just some ideas.
Jan 09, 2009 | Microsoft Xbox 360 Console
Screen showss double picture
Good Day, cs81801;
It sounds like the TV's Convergence Circuit has failed.First, try
to reset TV by unplugging TV from A/C source, for 2 to 5 minutes. Then plug TV back into outlet. Also, try the Magic Focus button on front of TV.
Still no work? To fix yourself call 1-800-458-6053 and ask for KIT 10. This will provide you with all the parts you will need. These are soldered in parts, or call an Authorized Service Center and have them give you a written estimate b4 repairs are performed. Cost? between $450 to 650 depending on your location and Service Center. Good Luck, big IRISH.
Sep 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Help
Sounds like a blown fuse in the power supply
Jan 18, 2008 | Hitachi 57S715 57" Rear Projection HDTV
Tv won't come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | Televison & Video
Mitsubishi WS-55511 55" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
