What does it mean if u get a green light when u plug in t.v. then the screen will blink on and off for a split second, the light turns blinking red indefinately. The t.v. will not turn on at this point. The only way to turn red light off is to unplug tv.?\
  • Mike Esse Jul 30, 2010
    what does it mean if u get a green light when u plug in t.v. then the screen will blink on and off for a split second, the light turns blinking red indefinately. The t.v. will not turn on at this point. The only way to turn red light off is to unplug tv.?\
    RCA L42WD22Yx5
  • 10,515 Answers
This is usually suggestive of ' hardware failure '.It could be a faulty power supply board ( in most of the cases ).If you wish to repair the TV, revert with make and model of the TV and i would be able to tell you few pointers to repair it,
Note - You need to have electronics repair experience , should know how to read schematics.You need to use multimeter and soldering iron ( if required ).
Let me know,if you wanted to repair it so that i could guide you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 30, 2010
    RCA L42WD22YX5
  • 10,594 Answers
I need model number and brand info of your tv to understand above said symptoms to diagnose possible cause of problem.
Model and brand info would be written on label pasted at back of tv.
Thanks.
  • 5 more comments
    model # is L42WD22YX5
    its an rca flat screen
    serial number H403CU03J
    model number L42WD22YX5
  • Shahid Electronics
    Shahid Electronics Jul 30, 2010
    OK, RCA, L42WD22YX5
    Blinking red light shows internal problem with back light inverter board that seems got problem for some reason.
    Visual check is necessary to measure supplied voltage to back light board from power supply board. Local tv repair shop will do the job for you if you do not have electronics knowledge/ experience.
    Required back light board is available with Shop Jimmy, click the link to have price info.
    Thanks.
    I got that info from your previous post and replied.
    Thanks.
    thank you ill check the board. thanks for the help
    No problem. Thanks
    Thanks for rejecting assistance.
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Samsung AQV24NSGN red and green light blink
The blinks are a code. If 3 red blinks, could be power board.
Apr 13, 2014 | Heating & Cooling
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Feb 12, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
