Question about Sharp AL 800 Copier
My Sharp AL-800 copier only returns blank pages even after I replaced the toner cartridge with a new one.
  • 52 Answers
Toner is not the problem remove the photoreceptor and gently clean the inside very well expecialy the two charging unit.
Posted on Aug 27, 2010
I recently changed my copiers toner (the change toner light came on) and now my copies are uneven (alternating in light and dark patterns). I properly shook the toner, I even returned the toner to get a...
The light and dark banding going horizontally accross the page is usually caused by the drum unit. This is the smaller of the 2 cartridges and it sits just to the right of where the toner sits. If you have a spare drum unit, replace it. This should resolve the problem. The Toner cartridge can also caus this but if you have tried 2 DIFFERENT units with the same banding then it must not be the toner.
Good Luck and Thank You for using Fixya.
Jun 15, 2010 | Sharp AL-1642CS Copier
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
Where is the ink carteridge located on the sharp al 800
The front operational panel drops down, exposing the toner cartridge and the drum cartridge. The toner is the uppermost one. for more see:
http://www.sharpusa.com/CustomerSupport/ProductDownloads/ProductFAQs.aspx?category=PrintersFaxMachines
Good Luck!
Jan 02, 2010 | Sharp AL 800 Copier
Sharp AL 800 won't copy bottom 2 inches across page. Replaced toner cart and still missing bottom 2 inches across page. What do I try next?
Pretty sure you need to replace the drum cartridge. When the drum blade goes bad or edges of the drum go bad it will cause this issue. You can stop a copy as it is passing thru and compare the edge as it is being transferred to the drum and what is on the paper to see what I am talking about.
I can be more specific if necessary
Thanks
TankMurdock
Apr 24, 2009 | Sharp AL 800 Copier
AL 800 falshes "L" - new toner cartridge inserted
Manual can be found here.
http://www.sharpusa.com/files/cop_man_soho_AL800.pdf
Apr 16, 2009 | Sharp AL 800 Copier
Poor quality copies
Hi, this is most likely caused by a worn or faulty drum.
Jan 20, 2009 | Sharp AL 1631 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Black line on side of copies
You should replace the drum and toner cartridge if you haven't in the 5 years, that should take care of the lines. The only problem is the cartridges can cost more then the machines is worth... Hope that helps
May 30, 2008 | Sharp AL 800 Copier
Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Dec 01, 2007 | Sharp AL 800 Copier
Sharp AL 800 Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
