Question about Sony DCR-DVD755/E DVD Camcorder
My Sony DCR-DVD755 Handycam sometimes during recording gives an error message "Disk cover open, Accidentally. Turn power on again" and on doing so, sometimes couple of times, it shows "Recording on disc disabled". The finalizing and unfinalizing is blocked. It shows the disc as fully recorded-which is not the case. Only re-formatting of the disk can bring the disk in use again. This means all data/video is lost! If anyone can help how to retrieve the 'lost data' on the disc? Any software? Banday
cropp
  • 377 Answers
SOURCE: Finalize cd-rw on Sony HandyCam DCR-DVD92
hi dear
you can finalize your dcr in record position
going to disc manager find the finalize
and finish
oke
Posted on Apr 07, 2008
SOURCE: Sony Handycam DCR-DVD108 - Carl Zeiss Vario-Tessar Optical Zoom 40x
Please, I need support of camera technical carl zeiss vario tessar with otptical zoom 40x
Posted on Oct 09, 2008
SOURCE: Accidentally deleted video.
Hi ihad the same problem as you. I did a search for free ware and ended up down loading free-undlete. It really was free. It took about 10 mins to download another 10 to search once my sonydcr-sr42 was hooked up. it was located in drive (f) and another 10 for all videos that could be retrived to pop up and then depending on the size 5- 20 mins to recover the videos. good luck. this was done yesterday 11/13/08.
Posted on Nov 14, 2008
SOURCE: DCR-DVD108 Problem
It's the disc not the camera......I purchased a 3 pack of Sony DVD-R discs. I put the first disc in and it recorded once. The next time I tried to record I got the message "movie recording disabled". After calling Sony, searching online, resetting the camera and reading through the manual I replaced the disc with another from the 3 pack and it is recording just fine. I read that recording straight to DVD has many problems, and I believe this is one of them. SONY SUCKS!!!!!
Posted on Dec 20, 2008
robmcd27
  • 423 Answers
SOURCE: C:13:02, Disc error. Remove disc. Recording disabled.
I'm sorry to say, that all disk manufactures are not the same. If you used a "no name" disk, then the quality may not be what you want, although in rare cases, even good companys like Memorex can make a bad batch or two. Just try another disk. Let me know if that works by leaving a comment. If this works for you, rate my solution a fixya!
Rob
Posted on Feb 25, 2009
Why do I see MEMORY STICK ERROR on my Sony camcorder?
Check the memory stick for a little slide lock on the side. Make sure that is not in the locked position. This feature is there to prevent people from recording over special memories, like weddings. But sometimes during handling (or just not knowing) people accidentally switch it to "lock"
Good luck
Oct 03, 2012 | Sony Handycam DCR-TRV350 Digital Camcorder
I need driver Sony DCR-DVD755 for my computer window-XP
cannot download recordings to computer.Computer detect but software is sometimes corrupt plz tell some remedy..
Sep 07, 2010 | Sony DCR-DVD755/E DVD Camcorder
Sony handycam DCR-DVD608 Error E:61:00
I have sony handycam dcr dvd 608,when I open my handy cam,the message is showing, movie record disable
May 23, 2010 | Sony DCR-DVD608E DVD Camcorder
Disk cover open, accidentally. Turn on power again
Haha, yes finally what a pOS!, But I got it!!
So I got to thinking well the sensor or something be messed up a bit. I found that the cover a very slight amount of play.
So hell , I put a C clamp on it. I started to record. Sweet, it worked!!! The cover was stuck so the sensor wasn't tripping.
Well that worked, but I didn;t want a c clamp on my camera all the time, so I had some Automotive Amazing Goop,
I lined the cover edges with the sealent and let it dry. Now when I close it , it stays closed and records without a problem.
The only thing is its tuff to open, I use a skrew driver, or small nail.
But it was unusable before, and at least I can use it.
Good luck.
Sep 25, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Error Message: Disk cover open, accidentally. Turn on power again.
When you open the door you will see 2 metal tabs that are sensors to that are pushed by 2 plastic tabs on the door that push on the metal tabs to let the camera know the door is shut. For whatever reason these tabs are not pushed up enough and I triggered them by sticking something in there to make contact. I used the end of a toothpick for now. May be primative but it works for now and I may look for a method to make it permanant but at least my camera works now
Jun 20, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Error message + disc opened acidentally + recording disabled
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Apr 12, 2007 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony DCR-DVD755/E DVD Camcorder Logo
82 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
