Question about Nokia 3220
Suddely the alarm is not working in spite of adjusting the time. It was working well since I purchased the phone. The icon of the alarm is shown on the screen
    Problem Solver:
  • 9 Answers
You should do a master reset. Sometimes this helps with weird problems. Just go into settings and choose default settings. The default password is 12345
Posted on Jul 30, 2010
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
Dec 06, 2013 | Timex T309TT Clock Radio
Setting the time on ascot projection alarm clock
Ascot AUPWE10 Projection Alarm clock. To change the main time and date. Push the Mode button until the temperature display is shown at the top. Then hold the mode button in until the the day function flashes down the bottom. Move to required field by pushing the mode button again. Adjust date and time displays using the arrow keys.
Mar 31, 2012 | Audio Players & Recorders
Iam using SAMSUNG champ DUOS ( GT-E2652) phone. its alarm is automatically ON every day @ 12noon. how i stop that
i encountered the same issue, its alarm every 12 midnight. what i did is a created a dummy alarm.
from the menu... go to alarm icon, create/set alarm an 12:00am, you can set it to everyday, or select any other options. once you done.. save the settings.
next, do not make this alarm settings active.
Jul 29, 2011 | Samsung Cell Phones
How to adjust date and time free of charge
You did not specify the phone you using.
To set date and time on your nokia phone
Select Menu > Settings and Phone > Date and
time.
Select from the following:
Time - Enter the current time.
Time zone - Select your location.
Date - Enter the date.
Date format - Select the date format.
Date separator - Select the symbol that separates days, months, and years.
Time format - Select the time format.
Time separator - Select the symbol that separates hours and minutes.
Clock type - Select the clock type.
Clock alarm tone - Select the tone for the alarm clock.
Alarm snooze time - Adjust the snooze time.
Workdays - Select your working days. You can then set an alarm only for working day mornings, for example.
Automatic time update - To update the time,date, and time zone, select On. This network service may not be available on all networks.
Regards
Jun 30, 2011 | Lands Phones
2 alarm times appear at the bottom of my screen. I only want one
I had the same issue. For the last few days I had the double alarm icon with the one you describe showing 8:00 am. I had no alarms etc set so I had no idea what it was until today at 8:00! A notice came up about a friend's birthday. Apparently when I was in my calendar a few days ago I attempted to put the birthday reminder on my calendar. In the menu I thought I selected "New" however just above the New option is the New Alarm option which is what I must have selected. When the alarm came up the icon went away from my home screen and the clock page. I went in and deleted this recurring alarm and scheduled it as I normally do on my calendar.
You probably have an alarm that either already came on by the time you have read this and you likely set it inadvertently like I did. I hope this helps.
Mar 15, 2009 | RIM BlackBerry Storm 9530 Smartphone
Sprint/samsung phone alarm
Is your phone rings when there's a call? If not, then it might your phone buzzer has the problem.
Oct 15, 2008 | Samsung Cell Phones
Random icon and alarm
The orange bell simply means that you've 'missed' your alarm... as in you haven't turned it off before it finished its alarm sequence. If you go to Menu - 'Missed Alerts' it should be shown in there. Click on it and say 'dismiss', the orange bell should disappear and the alarm should return to normal.
Sep 25, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Mar 13, 2008 | Nokia 7370 Cellular Phone
Alarm icon won't go away
try to master reset and master clear the phone.
Nov 24, 2007 | Motorola Mobility RAZR V3
Nokia 3220 Logo
24 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
