Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Oil dripping from front of engine onto exhaust manifold. Is there an oil additive that will slow or stop the leak?
    Problem Solver:
  • 5 Answers
Put a new gasket on the valve cover ort tighten the bolts on the current.
Posted on Aug 01, 2010
2005 Vespa PX150 reissue. Oil is leaking onto the exhaust, causing smoke. Where is it coming from and how do I stop it? It appears to be 2-stroke oil.
Haha, you can't be serious! The Vespa has a two stroke engine, and with out oil mixed with the gasoline, the engine will seize solid. You may have too much oil going in which is not being burnt in combustion, and is condensing on the inside of the exhaust, enough to drip out. That is far better though than not having enough oil. Have it professionally serviced and the oil correctly calibrated.
If you mean it is dripping onto the outside of the exhaust, that is a different kettle of squirrels. Find where the drip is coming from and tighten up the union. The tank is quite small and you will see a pipe going to the pump and then to the carb intake manifold.
Your manual is here
http://www.vespaklubljubljana.com/manuals/px150/PX150%202005%20Owners%20Manual.pdf
Jun 25, 2018 | Cars & Trucks
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Dec 08, 2014 | 2000 Kia Sephia
I cranked my car up this morning and for the last few morning when i warm it up it gives a burning smell. I dont see any leaks. What could the problem be?
check for oil leaks around the engine manifold check rocker cover for leaks if its a diesel check the turbo charger for leaks check wiring around exhaust manifold
Nov 07, 2014 | 2008 Mercedes-Benz Mercedes Benz C Class
Oil leak from behind exhaust manifold
do a compression test , check for cracked manifold .
Nov 06, 2013 | 1999 Daewoo Lanos
Smoke coming from the left side of the engine
this may be due to an oil leak getting onto the manifold or the manifold is cracked and exhaust gas is building up in the engine.
if smoke is intence and black this indicates oil.
if it is mid and grey blue this indicates exhaust gas
get checked by a mechanic
i hope this was useful.
Jan 24, 2011 | 2006 Chevrolet Blazer
My jeep is smoking under the hood and seems to be oil all over the engine.
check valve gaskets possible dripping onto exhaust manifold causing smoke or check transmission lines radiator back fan may **** it up and also spray manifold --power steering same thing first need to find what fluid is leaking --reddish tranny/power steering--brown/black[needs changing]engine oil---neon green anti-freeze good luck
Jan 22, 2010 | 1999 Jeep Cherokee
My toyota vienta 3VZ-FE 1996 - oil leak onto exhaust
That engine will leak oil from
- cam cover gaskets (rear one drips on the exhaust)
- camshaft end seals
- distributor shaft o-ring (appears on top of transaxle housing)
- oil filter bracket to block o-ring seal (drips on front bank exhaust)
- crankshaft nose oil seal (have done with timing belt change)
- rear main seal (expensive, leave it be)
Dec 06, 2009 | 1996 Toyota Camry
Burnt Oil Smell
Check carefully around the valve covers, this is the area that leaks most frequently occur, and being located next to the exhaust manifold can easily cause the burning smell. There is a very easy to replace gasket under the cover. Other possibilities, shop or you when changed or added oil spilled a bit and that has worked down to the exhaust manifold and is causing the burnt oil smell. Last possibility is that you do have a slow leak on the underside of the engine that is blowing back onto the exhaust system causing the smell.
May 22, 2009 | 1998 Oldsmobile Intrigue
Oil leaks onto the manifold pipe
I had the same problem check the oil sensor switch located above the manifold it is electronic with to wires I leaks when bad
Oct 20, 2008 | 1994 Toyota Camry
Leaking Oil
No,the only good solution is to replace the seal.I have tried different additives and none seem to hold up very long.Good Luck!!!!
Aug 04, 2008 | 1994 Isuzu Rodeo
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
333 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
