Question about iRiver H10 MP3 Player
Iriver h10 I have had it for a while now and it has worked fine. Now I can't get sound. If you mash on the back a certain way, the sound will come on for 1 second. I released the battery and put it back. I even tried my friends battery which works fine on hers.
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 27, 2008
"Black screen of death" iriver H10 6GB color
sounds like incorrect charging voltage and amperage may have fried some of your components.
Could try selling it on ebay as-is to make some money toward another unit.
You can get a top notch 20gb refurb unit from ebay sellers (like metromania) for $40-60. I have 2 refurbs and 1 built from parts from as-is units.
Mar 07, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
H10 20GB Freezes When I Try to Play certain MP3
try connect to a computer then reformat it..
Feb 05, 2008 | iRiver H10 MP3 Player
System files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
Iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Mar 28, 2007 | iRiver H10 MP3 Player
Iriver H10 20GB
They don't make a battery for the player. My experience with iriver is that they only replace your player with another refurbished one if it's under warranty. Contact iriver.com and go to support, they will help you to a certain point. Sounds like some music files are corrupted, did you download them from Limewire? Lots of nasty stuff out there. Remember your player is a Hard Drive just like your PC and can be damaged by improper disconnect from your PC. Regards, John H.
Feb 07, 2007 | iRiver H10 MP3 Player
IRiver H10
Require more history 1/condition of H10 battery B4 this problem (blown Charger Fuse) occurred 2/perhaps battery condition severly depleted creating high current draw upon initial charge attempt 3/not certain if an circuit protection fuse exists in H10 4/Chk charger wiring for shorts bare contacts etc.
Nov 27, 2006 | iRiver H10 MP3 Player
Iriver backlight not working
Take the battery out and put it back in again.It worked for me!
Oct 02, 2006 | iRiver H10 MP3 Player
My h10 will not switch on, iriver support will not help
Try to reinstall the software CD you received with the player. Good luck
May 01, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
24 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
