Replacing cracked laptop screen
I have an advent modena laptop and im replacing the LCD screen as its cracked.. i have unscrewed the bezel but it wont fully come off as sides are attached to board beneath. anyone know a solution?
    President:
  • 2,600 Answers
The side rails are the hinges, in some cases you most remove or loosen the screws that attach the hinges at the bottom where the hinges attach to the lid. Once this is accomplished, the hinge supports will allow access to the sides of the screen in order to remove the lcd panel. Once the panel is released from its side attachments, the data cable can be pulled free from the back of the panel.
Posted on Jul 30, 2010
Wallpaper on laptop wont work
right click on any paicture in your computer and select set as walpaper. If it doesnot work, reinstall Operating syste,.
Apr 06, 2014 | Advent Modena M101
Advent modena m101 web cam driver
Try this site for the driver download. http://www.downloadcollection.com/freeware/advent-modena-m101-webcam-driver.htm
Jan 24, 2013 | Advent Modena M101
Advent modena m200 not starting at all.
reboot the system with F8 AND select safe Mode or last good condition was working before and execute.
Proceed to the RUN the CHKDSK.exe ,
download update windows.,antivirus+malware..
Otherwise, you must get support via online chat or phone with the
supplier for assistance.
God bless you
Sep 28, 2012 | Computers & Internet
Screen on laptop advent 7102 very dull can hard use it hardly any brightness
The LCD screen for the Advent 7102 does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (Screen Inverter) converts electricity from the laptop, for the LCD screen, and the Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The Inverter is a small circuit board located behind the Display Bezel, and under the LCD screen.
[ The Display Bezel is the thin plastic frame in front of the LCD screen. Resembles a picture frame ]
Example of a screen Inverter for an Advent 7102 Netbook PC,
http://www.laptoppowerjacks.co.uk/category-27/Acer12.html
Regards,
joecoolvette
Oct 17, 2011 | Advent Netbook
I have an Advent Modena M200 red. It has a built in webcam, but I can't figure out how to get it to work? I also have some screen pixels missing, is this a fault? Thank you, in advance, for your help.
Hi, trisha_king!
To configure a webcam make sure you have the right drivers installed. Head over to the control panel and configure it on the camera settings.
Dead pixels or "missing" pixels are an issue that most LCD screen have and there's nothing that can be done about it. Though if you have enough for it to hinder the use of your laptop you should get it replaced.
If this didn't fix your issue please let me know. Hope this helped you!
-Luchen
Mar 07, 2011 | Advent Netbook
Cracked LCD 10'2 ADVENT 4211c screen
OK. This may be difficult for you. You need to completely remove the screen from the housing, remove the old screen, put in the new one and wire it all up. If you want to do this yourself, I can help you, but you may wish to have it done by a computer shop to make sure there will be no problems. My email adress is lmattheus@hotmail.co.uk.
Sep 07, 2009 | Advent 4211c Notebook
Cracked LCD Screen for Advent 4211C Netbook
try this site if they don't have it e-mail the guy he can help you I been with him since 2000, its http://cbear.net/laptopandaccessories.aspx
Jun 27, 2009 | Advent 4211c Notebook
Replacing Laptop LCD Screen
you'll need to remove the screws holding the screen bezel (the plastic around screen) on...they'll probably be under little circular plastic or rubber covers....gently pry these out as they'll go back in place when you reverse the procedure....should be four of them....Gently pry the bezel away from the main screen housing ...once thats done....you'll need to unscrew the screws holding the screen onto the hinge plates...(again should be 4 of these)...screen should now be free
NB be careful when screwing in the new screen to the hinge plates as overtightening can sometimes crack the screen
Dec 15, 2008 | Compaq Armada E500 Notebook
Amilo Pro V2010 base removal
Hi
The inverter is in the laptop screen, not the base.
1 remove the screw covers and then the screws surrounding the laptop screen
2 gently prise the screen bezel away from the screen, best done when the laptop is opened out almost flat
3 the inverter is at the base of the screen, gently unscrew and unclip the inverter from the LCD screen
4 take replacing the inverter to make sure all the leads are safely housed
5 replace screen bezel and away you go
Oct 11, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
281 people viewed this question
Alun Cox
David Payne
David Payne
