Question about Vacuums
I need to change a fuse in a g4 kirby - Vacuums
    President:
  • 1,673 Answers
There is no fuse. If it isn't working, check the cord with an ohm meter to see if one side is open. If one is, then replace the cord. Could also be the switch or a problem with the motor.
Posted on Apr 24, 2008
Kirby g4 stoped working
cable has shorted out internally, will need new cable
Nov 18, 2012 | Kirby G4 Bagged Upright Vacuum
I am looking for a service manual for my Kirby G4D vacumn.The number on the vacumn is 7941006690. Sounds like there is something caught in the motor or fan . I am not sure how to take the vacumn apart...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/G4/8D4538EC00E93846200D614F7C499B59/G4%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 17, 2011 | Kirby G4 Bagged Upright Vacuum
Kirby g4 tech drive, when plugged won't come on ,is it the motor or something else ?
Does anyone know if there is a reset button on the Kirby G4? And if there is where it is?
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
My kirby g4 will not turn on. I have checked the fuse and flex, the switch sounds good. pleas advice
ensure the front housing is properly fitted and the bottom of the bag housing that attaches to the machine, if these are not located correctly the safety switches will not allow the vacuum to start.
Could also be the mains cable, any damage may not be visible on the outside.
Or the motor brushes may be worn out, you will need a professional repairer for this.
Oct 05, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Vacuum/Shampooer
i find the kirby carpet washer is rubbish coz it leaves all the dirty water in your carpet and it goes smelly!
Jul 06, 2009 | Kirby G4 Bagged Upright Vacuum
G4 kirby
ensure the safety switches are made properly by making sure the front brush assembly is fitted properly, you will see a tag that enters the machine making the front switch, secondly make sure the bag bottom housing is on properly and fully rotated so that its tag makes the switch on the side.
The only fuse is in the plug (UK).
Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Jul 24, 2008 | Kirby G4 Bagged Upright Vacuum
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Manual and tools kirby g4
The first link is instructions for changing a belt. The second is for the shampooer instructions. If you click on the links below, it will take you to my online guides and if you look there, your other question will be answered. Thanks!!
Marci
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Oct 29, 2007 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
57 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
