Question about Refrigerators
My everstar ice maker stopped making ice. The motor was running but all the ice had melted. I just cut the machine off.
    Genius:
  • 1,478 Answers
If your ice maker is not producing any ice at all, it could be due to various reasons. Firstly, check the right side of ice maker for a wire. The wire will be in an erected position, if the machine is turned off. In such a case, lower the plastic lever present in there or the wire directly if there is no plastic lever. This should be enough for your ice maker to start functioning once again.
There could also be a case of blockage in the ice maker fill tube. If this is the situation, use a hair dryer to melt any ice stuck in there which is causing the blockage. Replace the tubes if necessary. Check the ice maker assembly for any cracked up or broken parts. Especially check the gears and plastic arms along the ice rake, as these are more likely to break down compared to other parts. Replace them if needed.
Take care.
Posted on Jul 30, 2010
  • Otis Watkins Jul 30, 2010
    There is no wire on the right side of the ice maker. If there was a situation of blockage within the line it should be melted by now due to the fact the machine has been off for a while. Water seems to be running through the machine because I can here it running and see it at the top of the machine. Is there anything else that could be contributing to the machine malfunctioning. Thank you in advance for your support it is truly appreciated.
  • Jimoh Adeleke Muyideen Jul 30, 2010
    1) If the icemaker
    doesn’t make ice but you can see the arm swing into motion and you hear a
    buzz for about 10 seconds after it is finished, the water valve is
    asking for water that isn’t arriving. This means the valve and the
    solenoid are probably okay, but the water supply is not. Be sure the
    water supply line isn’t kinked behind or beneath the refrigerator
    (1/4-inch copper tubing is much better than plastic fill line).
    2)
    Check to see if something has caused ice to back up around the
    mechanism—this can cause the fill tube to freeze, blocking the
    mechanism. When ice cubes are small and seem to be getting smaller, it
    generally indicates a frozen fill tube.
    3) Check the water line
    that enters the back of the freezer for a blockage. Find the water
    shut-off valve behind the refrigerator or under the sink, turn it off,
    unscrew the copper line from the back of the refrigerator, put the
    copper line in a bucket, turn on the valve, and see if pressurized water
    pours out.
    4) Check the tap valve; a bad tap valve may cause the
    problem where the icemaker’s supply tube connects to the water pipe. If
    necessary, replace the inlet valve and the tap valve. For the tap
    valve, use the type that requires you to drill a 1/4-inch hole (as
    opposed to the “self-piercing” type). You can do this yourself, or call a
    repairperson or plumber to install an inline water filter when
    replacing the valve.
    5)
    The water line attaches to a solenoid at the back
    of the refrigerator and then travels to the icemaker. The solenoid may
    be defective or may not be receiving power. You can try removing the
    sediment screen inside the solenoid and flushing it with water to clean
    it, and at the same time you can inspect any seals or diaphragms to
    ensure that they are sound. Unplug the refrigerator first. Unless you’re
    skilled at home repairs, this job is better left in the hands of an
    appliance repairperson.
    ch_client = "donvandervort";
    ch_type = "mpu";
    ch_width = 300;
    ch_height = 250;
    ch_non_contextual = 4;
    ch_vertical ="premium";
    ch_sid = "Article pages: Secondard ad slots";
    var ch_queries = new Array( );
    var ch_selected=Math.floor((Math.random()*ch_queries.length));
    if ( ch_selected
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 15, 2012 | Emerson Im90 Portable Ice Maker
I have everstar brand ice maker but makes ice melt
For Residential customers: 1-877-261-9867
For Commercial customers: 1-866-837-5277
To order parts:
Call 1-800-521-9201, or
Fax 1-800-722-0481
If you prefer to use e-mail, send your orders or inquiries to
franklinchef@partwizard.com
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Refrigerators
Seems to make ice but will not keep it cold therefore it melts. It does this about 3 or 4 times a year but after staying off it will start working again
The only thing that keeps the ice cold is the ice itself. If the icemaker isn't making ice fast enough then the ice will melt before more ice drops to keep it cold. In other words the motor ice the slower the ice melts. Now if the door gasket isn't sealing properly then the ice could melt to fast. Also the ice is going to melt some and when it does the water has got to drain out the bottom. If the water doesn't drain the ice will be sitting in water and will speed up the melting process dramatically. I hope this helps!
Sep 28, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Ice maker stopped making ice. I had to melt ice
Jim, you will need to replace the heating element and most likely once this has been replaced, your ice maker should work properly unless the ice broke another part on your ice maker.
I would start with the heating element first.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct part out to you asap!
We look forward to getting your ice maker working properly again soon!
Thanks, Ella
Nov 09, 2009 | GE Profile Arctica Stainless Steel Top...
My freezer in my side by side Maytag Refridgerator is not keeping food cold -everythings melting -ice in ice maker is melting - motor is running but making periodic clicking sounds.
turn the unit off at the motor/compressor is over heating hence the clicking noise when it cuts out. Defrost it with both doors open for 48 hours. then try it again.
Mar 27, 2009 | Refrigerators
Everstar Ice Maker
Hopefully you have a filter before the ice maker. Replace this (if you have one) at least every 6 months.
ap
Ice maker will not make ice
This is a Franklin ice maker and here is a link to the manual http://www.franklinchef.com/pdf_info_phase_4/FIM35%20C%20Manual.pdf.
Nov 14, 2007 | Carrier Beverage Air DD68C Commercial...
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
