Question about Eaton ARC FAULT CIRC BREAKER
15 amp breaker will not reset with all load off.
  • 2,100 Answers
They are sensitive little ****, I know they won't work on a florescent fixture, no lights should be on it anyway, but just in case, and the slightest thing wrong, one wire off, one ground undone, it will snap off. And they do go bad, so don't tear the house down to find the trouble when the breaker might be bad. Hook the wire into an existing 15 amp breaker and see if it snaps that off. Then you will know it is not the breaker but something in the wall. Check it out.
Posted on Jul 30, 2010
4 Suggested Answers
  • 885 Answers
SOURCE: I have a 15 amp break that tripps due to over load
You will solve the problem of the breaker tripping but you'll create a fire hazard as the wiring may overheat because of what you are drawing through the line. If you need a higher amp circuit breaker for the load you are creating on the line, you need to make sure the wiring can also handle the extra load. You'd be way better off by spreading the load over several different circuits or installing another line to reduce the load on the line that's tripping the breaker.
Posted on Nov 13, 2010
al_kupchella
  • 843 Answers
SOURCE: I have a 15 amp air conditioner, with afci plug on
It's definitely not related to the 20 Amp breaker. You do mean GFCI, right? The kind built into the end of the cord on the air conditioner, right? The GFCI is either detecting a ground fault (which means it's doing it's job and there is something wrong with the cord or the unit) or you have a bad GFCI. If the GFCI is in the wall receptacle, that could be a different story.
Posted on Jun 24, 2010
frcs68
  • 1605 Answers
SOURCE: I have 2 siemens circuit breakers that won't reset. How can I do
unplug the appliance that is overloading the breaker.
reset the breaker, plug in the appliance. if the breakers pops, then the appliance is the problem.
you may want to check the appliace manual and make sure the breaker is rated for the appliance you are using.
Posted on Dec 30, 2008
Holmes hch6150 will not produce heat
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
Feb 13, 2015 | Heating & Cooling
How many 5 watt outside lights can you power with a 20 amp breaker?
Volts x amps= watts.
20 amp breaker x 125 volts = 2500 watts.
However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
Keep in mind that most switches are 15 amp, and not 20 amp.
Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 22, 2012 | Home
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Hi, we have a square d 200amp ckt brker that we want to reset after we take our generator offline. we noticed that there is a black plastic tab that prevents you from resetting it. how can we reset it?...
Do you have a Square D "QO" panel - or a Square D "Homeline" panel (or a different brand panel completely)? If possible, please provide the catalog number of the circuit breaker.
Nearly all circuit breakers that are TRIPPED (handle is at the midpoint between ON and OFF) must be RESET by pushing the handle to the OFF position - then pushed the other way to the ON position. A circuit breaker that is in the OFF position, does not need to be RESET, and need only be pushed to the ON position.
It is advisable to shut off ALL the other circuit breakers in the panel, then turn on the 200 amp breaker. After the 200 amp breaker is on, turn on the largest value (in amps) double pole breakers and finally all the single pole breakers largest values down to 15 amps. This prevents switching one very large load all at once.
Aug 29, 2011 | Square D Qo 200 Amp 40 Circuit Indoor...
I had a breaker WLL3F340 (4000 AMPS ) and i need to reset ( back on) please i need you help , thanks.
A 4,000 amp breaker that has tripped indicates a a load greater than 3200 amps has been connected continuously for an extended period of time. A 4,000 amp circuit breaker is rated to carry 80% of the load - or 3200 amps continuously. Up to 4000 amps may be carried for a short period of time. A 4,000 amp breaker that has tripped can be a warning sign of a major problem.
First, 4,000 amps is a substantial amount of current. The reason for the breaker tripping should be determined and cleared by qualified persons before attempting to reset. Many circuit breakers this size have internal motors to charge a spring mechanism to close the breaker. Unlike the much smaller 15 to 50 amp breakers in your electrical panel in your home, these circuit breakers are also not designed for repeated tripping and resetting.
Second, no one is going to tell you how to do this either on the web or even over the phone. It is simply too dangerous to simply go for a reset without checking and clearing the cause of the fault.
Third, you should contact an electrician that has experience with large, commercial or industrial electrical service equipment. Not every electrician knows how or has worked with equipment this large, so be sure to ask first.
I hope this helps & good luck to you.
Jul 08, 2011 | Siemens Hammering
I have a 15 amp break that tripps due to over load in the amount of outlets being used, can I replace the breaker with a larger amp breaker to solve the problem
Nov 13, 2010 | Siemens Electrical Breaker 15 Amp Single...
How to reset Cutler Hammer 1 pole 15 Amp
Turn handle to off position and then back on. Same as any other breaker. The red test button can be pressed which will trip breaker. If it trips immediately,unplug all devices on circuit and try to reset. Reconnect each device and see which trips breaker. If this goes to outdoor receptacle, check behind cover for moisture.
May 25, 2010 | Cutler Hammer 1 Pole 15 Amp Ground Fault
I keep reseting my 15 amp breaker daily. I even moved the unit.
No. The unit is only supposed to pull 9.1 amps. (wattage divided by voltage equals amps) Your unit has a short, or your breaker is bad. Turn on the unit, when it trips the breaker see if the breaker is hot, If so, thats an indication the breaker is bad.
Apr 11, 2010 | Danby DMW112 Microwave Oven
Dec 25, 2008 | Siemens 2 single pole 15 amp breaker
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Eaton ARC FAULT CIRC BREAKER Logo
785 people viewed this question
Top Eaton Electrical Supplies Experts
john h
Steve
Are you an Eaton Electrical Supply Expert? Answer questions, earn points and help others
