Question about Panasonic VB-44223 Corded Phone
I can't access an outside line on extension 100, main phone and have no access to voice mail
    President:
  • 567 Answers
Hi please check the settings on the phone to see if its correct
Posted on Jul 30, 2010
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
How do I change the current extension on my polycom 301 phone from 334 to 300?
Go to support on the new phones manufacturers web site and you can download an owners manual, which will tell you how to re-program the phones extension. murf427
Aug 01, 2012 | Polycom IP 301 SIP IP Phone
How do we set up the phone system so that an outside caller can call our extension directly without having to go through reception/main unit?
There are a couple of ways. The easiest one is to use the Panasonic voice mail system which has an auto attendant built-in. It can be programmed to answer incoming calls, play a menu and let the caller dial extensions or ring the operator. If no one answers, it can take messages and provide the voice mail for the system. The TVA system has a LAN card that can send voice mail to email. It's optional in the TVA-50 and included in the 200.
Carl
Mar 14, 2011 | Panasonic KX-T7630 Corded Phone
I have 1 extension that will not go to voice mail. I have tried the *713 and a 2 digit number between 00 and 99 and it still just rings endlessly. When I make an inner office call to this ext... it picks...
What happens when you TRANSFER an outside call to that extension? If that works, you have Intercept issues which is handled with programming. If it still does not transfer, you have CF issues, started by a *710x command for both internal and outside calls.
Carl
Aug 11, 2010 | Panasonic KX-T7633 Corded Phone
How do you take out voicemail from the phone so call forwarding can be processed?
I'm not sure that you are phrasing the question correctly. How can I bypass the voice mail box would be a better explanation.
If you take out the voice mail box it will go to the main greeting. Call forwarding to voice mail is call forwarding being processed. Is there somewhere else you would like it to forward to?
If you are just trying to delete your mailbox then you need to know your system manager info. If you do email me at IsaiahJ1980@gmail.com and I can help you further.
Call Forwarding Options:
From Port 1
Find port 01 or Tel 01 by pressing feature 4 from the lowest extension # in your system. Once you have found port 01 dial either of the following:
Call Forward Busy No Answer
Speaker 45, enter the extension you want to forward i.e 103, enter the destination, another extension perhaps 107 and speaker.
Call Forward Busy No Answer to an outside #
Speaker 45, enter the extension you want to forward i.e 103, press 9 and enter the destination phone # and speaker.
To Cancel Call Forward BNA
From port 1: Speaker 46 and the extension #
Call Forward All
Speaker 47, 103, enter the destination extension 107 and speaker.
(You will notice the Feature light flashing after this operation)
Call Forward All to an outside line
Speaker 47, 103, 9, enter the destination phone # and speaker.
To Cancel Call Forward All
From port 1: Speaker 48 and the extension #
Nov 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
AVAYA PARTNER ACS PHONE SYSTEM
Yes it can. Depending on the type of voice mail attached to your system you can both have the lines answered with a seperate main greeting (partner messaging can do this) or answered by a seperate mailbox (all partner voice mails).
Oct 06, 2009 | Lands Phones
Voice Mail Access with No Phone Terminal
you should be able to dial the voicemal system internally and it will prompt you for your box number and code, or from outside the system there should be a code that will allow you to enter voicemail from the main menu of the auto attendant
Dec 23, 2008 | NorStar M7324 Telephone
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Unlocking the security cide to access teh mailbox?
Find out who has administrator access (usually extension 100) and use that phone, call voicemail, press "more" press "MGR" press "CHBX" listen to the voicemail which will prompt/ask you if you want to delete the security code. Say yes!
Nov 06, 2007 | NEC DTU 8D-2 Corded Phone
Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
8e5e1dd.jpg Hope this helps someone?
vandata1
Sep 27, 2007 | Inter-Tel Axxess Corded Phone
Panasonic VB-44223 Corded Phone Logo
27 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
