Question about RTO Atwood DSI-RV Water Heater-6 Gallon
I have a g6a-6e heater, wasn't working so replaced solenoid valve and igniter, same as before, when i switch it on, there is spark, i can smell propane faintly, i can hear the solenoids click, about 5 or 6 seconds later spark stops and solenoids click off, no flame
motor1258
  • 6674 Answers
SOURCE: I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
Posted on May 25, 2010
motor1258
  • 6674 Answers
SOURCE: Have an G6A-8E Atwood water heater. It Starts fine...
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
Posted on May 26, 2010
  • 57 Answers
SOURCE: I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Posted on Jun 07, 2010
motor1258
  • 6674 Answers
SOURCE: I have a 1992 bounder mh ,6a6e atwood water
First check thermal cut-off that is connected between incoming power wire and thermostat terminal. (located inside little clear plastic sleeve) Easiest way to do that is to remove it from the circuit temporarily. Just pull it off thermostat terminal, pull it apart from other end, and just connect female spade from incoming power wire directly to thermostat terminal. Then see if water heater ignites. If it does, and all works well, get new thermal cut-off. That cut-off is a safety feature in case of flame up at burner, it will shut off gas supply. It is not reset-able, just works once then needs to be replaced.
If that doesn't cure it, take a 12v test light, or a multimeter, and test for power at gas valve, when water heater is trying to ignite, or at ECO terminal where red wire runs from left ECO terminal to gas valve. If power is getting to gas valve, and you don't hear or feel it click, make sure ground connection is sufficient as well. If you have 10.5-13.5 volts to gas valve, and it's not opening and ground is good, then it's faulty and should be replaced. If it is clicking, (opening) but no gas coming through, you may have a plugged orifice on gas valve, provided you have cleaned burner tube of any spider webs or debris previously. If no voltage from red wire, start back tracking with meter or test light to other terminal on ECO, then to terminals on thermostat as well. You'll see how feed wire (short jumper) goes from thermostat, over to ECO. Remember, you will have to hold test light or meter probe at connection and have someone turn on switch to get a reading, which will only appear when it's trying to ignite. Let me know what you find.
Posted on Dec 06, 2010
motor1258
  • 6674 Answers
SOURCE: Atwood Water Heater G6A-7E, electronic
You are correct, there should be no flame after it shuts off. Pull the + wire off at contacts as well and see if flame remains, if it does, the gas valve is faulty (leaking by) and should be replaced.
Posted on Jul 22, 2011
Need to add electric heating element and thermastate to g6a-6e gas water heater
I don't know how you can drill into aluminum tank and install element.
That seems a good way to ruin the heater.
Why not just buy small 'under counter' 1500 watt electric water heater at local box store and install in-line before the water reaches atwood gas heater.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Otherwise I do not have a solution.
Don't blow yourself up by messing with gas appliance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 16, 2013 | Water Heaters
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
Heater has low voltage and will not run
check high limits and incoming voltage maybe low battery voltage or bad converter
Nov 28, 2012 | Atwood Mobile Products Atwood G6A-8E...
G6A-8E Water Heater will not start.
x8h3rkvosvawaaaaabjru5erkjggga=
You may need new circuit board, call mfg they may offer more help in determining if a new board is needed.
Good luck
Oct 28, 2017 | Atwood LP Gas Water Heater 6 Gallon 96121...
Need to replace G6A-6E Atwood waterheater, what replacement model can I use?
Why not the same model/size? Atwood 6 gal, works on propane with electronic ignition. Or, you can get the 6 gallon with electronic ignition, and electric element as well provided you are willing to run hydro to water heater as well, if not already there. Check any RV parts site for prices and availability. Some places are out of stock currently. I assume your current tank is leaking?
Sep 29, 2012 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood waterheater model # G6A-8E. I am having issues with no spark from the ignitor , I have used a long stem lighter to light the burner. It lights and burns well for a couple second seconds...
When you turn it on and hear the ignitor clicking, test for 12 volts at power wire to gas valve. If your not getting 12 VDC to gas valve when ignitor is sparking, replace module.
Jul 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Suburbun rv waterheater 10 gallon with electric ignitor makes clicking noise because it'strying to ignite but it's like no fuel is getting to it to start.
I had a similar problem, I could hear the valve clicking and spark working, but no flame. I checked for voltage as per the previous post, and checked continuity of both coils. Both showed voltage and continuity, but the ohm reading on one coil was less than the other.
I called a rv repair shop looking to buy a new valve ($120 - ouch). He didn't have one and when I explained what I had checked, he said could be that only one valve is opening. He suggested I remove one wire from each coil, turn the heater switch on and when I hear the spark igniter, touch a wire to one of the coils at a time. If it clicks, then it's fine, if it doesn't, then it could be the coil that needs replacing or the valve is stuck. If you see a spark as you touch the wire but no clicking, then it's a stuck valve. If there's no spark, then it's most likely a defective coil. A stuck valve can sometimes be freed by tapping with a screw driver.
In my case, one valve clicked, the other didn't and no spark was seen so I had a defective coil.
The previous poster is right, replacement coils are not offered as a replacement part - but - the repair shop I talked to saves all the coils out of old heaters and I was able to buy one from him for $10.
Problem solved, heater now works!!
Jun 27, 2009 | RTO Suburban Rv Water Heater Dsi Gas Valve...
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
85 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
