Question about Cavalry Storage Cavalry 500GB 3.5 7200RPM USB 2.0 External with One Touch Back-Up 500 GB Hard Drive
My computer (HP Pavillion p3101) won't see my external Calvary drive (500 gbcaue37500) It worked a few times and now I can't access it.
  • 48 Answers
Press the start button and right click "my computer"-> Manage -> Storage -> disk management. It can take up to a minute before displaying your discs. Rightclik your 500 gbcaue37500 and and depending on what's avaible;
Change from offline to online
initialize
Assaign a drive letter to the drive
  • If my solution helped, feel free to rate it!
Posted on Jul 30, 2010
My Buffalo hard drive was working fine but my computer had virus. I removed the virus and then copied a few files to the external hard drive. Later I realize that the virus wasn't completely remov
Consider a low cost data recovery service such as http://FreeDataRecovery.us
They do remote access data recovery over the internet and also offer do-it-yourself data recovery advice.
Oct 18, 2012 | Buffalo Technology HD-PX500U2/RD 500 GB...
My wd pasport essential is not running when i attach it to my computer(hp dv6 pavillion). the light comes on but it will not open.
this drive is probably protected. you should try to unlock it first before you can access the drive.
when you plugin the drive you should have a temporary drive where unlock application resides.
run the application then type in your password.
if you don't have the password i guess there is no way to access the drive.
Sep 14, 2011 | Western Digital My Passport Essential...
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
Info: barracuda 500 gig in a kingwin elite enclosure (sata) - usb to computer. being used as a backup and storage drive on H.P. Quadcore running windows vista. Prob: Cant be seen on any computer ive...
Quite commonly on external drives the usb interface will go bad in the external drives the hard drive enclosed is probably functioning ok. Would try a different usb cord just to make sure the cord is not the issue. If still does not work you may need to purchase a new enclosure that will have a new usb interface circuit board with it. If taken in for service they will probably tell you to purchase a new external drive.
Here is a video on recovering data a side from an external drive.Some steps are not necessary if you have access to an ide/sata to usb adapter. These are pretty inexpensive on ebay as well as replacement enclosures.
http://www.metacafe.com/watch/1000351/recover_data_from_external_hard_drive/
May 01, 2011 | Seagate Barracuda 7200.12 ST3500418AS Hard...
My Calvary external 500GB hard drive is not being recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Sep 21, 2009 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Calvary 1TB USB 2Bay external hard drive problem
The problem could be the enclosure, not the drive.
I would take the drive out of the Calvary enclosure and install it in another one. Hopefully it will come up and you can access your data.
Jun 15, 2009 | Cavalry Storage Cavalry CADB001U32 1TB...
My computer doent recognize my external hard drive
disconnected from the computer and reconnect.
if it still doesn't recognized the device, disconnect and shut-off the power and wait 1 or 2 min. than re connect again.
with all that, if the machine still can't recognized the drive, then the drive need to be check with another work machine, make uure it is in working condition.
Dec 05, 2008 | Western Digital My Book Essential Edition...
WD My Book 500 GB external drive sometimes clicks, but still works?
Does it seem to work properly and in a timely fashion? If so don't worry about it. Since it is an external drive it may be slightly quieter than you are used to. Laptop HDDs barely make a sound....
Also keep in mind if there is hardly any data on it, it's not going to have to make much noise to begin with.
Aug 25, 2008 | Western Digital My Book Essential Edition...
CAlvary 500 GB CAXE37500 not switching on
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Kind Regards
Andrea
Jun 04, 2008 | Cavalry Storage EXTHD 500G|CAVA U2&ESATA...
Cavalry Storage Cavalry 500GB 3.5 7200RPM USB 2.0 External with One Touch Back-Up 500 GB Hard Drive Logo
156 people viewed this question
Top Cavalry Storage Computers & Internet Experts
Arora Singh
Arora Singh
gary433
Glenn Smart
Glenn Smart
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
