Question about Dometic Rooftop RV Air Conditioner
Freezing up The exchanger that provides the inside cool air is freezing up. It looks like the thermo couple came loose - it looks like it simply pushes between the vanes of the exchanger to detect how cold it is and allows the unit to cycle - before I put it there, I wanted to be sure that it doesn't mount somewhere else that I can see.
  • Dometic Master
  • 43,501 Answers
That would be the bulb for the exspansion valve and should be strapped to the copper where it exists the coil...
But that is probably not why it is freezing up....
That is more likely caused by a slow leak that has the unit undercharged or a bad air flow...often caused by a plugged coil or air fliter...
Here is a tip for other things you can check....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 30, 2010
What are heat exchangers used for?
Heat exchangers are a commonly used mechanical element of a lot of day-to-day things. Some of the most common uses of heat exchangers are:
- As mechanisms in air conditioning units
- As a component of refrigerators
- To heat or cool swimming pools
Most manufacturers of heat exchangers provide heat exchangers to businesses for industrial purposes. Heat exchangers are an effective way of making the most of heat energy. A good example to illustrate this can be found in how heat exchangers are used in cars and buses. Most buses use heat exchangers to use the heat from the engine to warm the bus. This is a more effective way to use the energy than using electric heating. Car radiators are also a form of the heat exchanger as they use cold air from outside to cool the water and keep the engine working properly. The heat loss from the radiator is then used to warm the inside of the car.
May 21, 2018 | Heating & Cooling
Tip
Heat Air Exchanger for Heat Recovery
An air-to-air exchanger is used to recover heating or cooling and to improve the air quality of the building that it serves. Typically an air exchanger has two fans, one blowing air into the house and one blowing air out of the house. In the winter time the one fan brings the outdoor cool air through the core warming it with the warm stale air you are exhausting. In the summer time the warm air from the outside will be cooled as it enters through the core to save on your cooling.
Air exchangers often are used to perform many functions such as reducing air contamination, heating or cooling air entering the building, and humidifying or dehumidifying air before it enters the building. Air to air heat exchangers or heat recovery ventilators, are used to provide a balanced flow of air into and out of a building. Ultimately an air exchangers main function is to switch the stale inside air with fresh outside air while exchanging the heat or cool in the process.
There is some controversy about the savings of exchangers. Not only does it require electricity to run the air exchanger, but the air the exchanger brings into your house must be brought up to temperature. This may require that more electric is used to cool your building or that more fuel is also required for heating.
The amount of air that these air exchangers bring into a home may vary depending on how the system has been installed. The codes in many places require a minimum amount of air to be exchanged. Check with your codes official to see what the requirements are for you.
Air exchangers can be a very good thing for many buildings. Especially those that are very large and typically have a lot of occupants with little natural air exchange from doors or windows being opened. However they are also a health hazard if they are not serviced
All air heat exchangers will require regular maintenance. The problem is that this is almost never performed by homeowners, and unless they know about the exchanger it is often overlooked by contractors during service calls. The real problem is that clogged, air-to-air exchangers can make the indoor air significantly worse than it would be without the system installed at all. If you have a home that already has a heat air exchanger, make sure that you keep it very well maintained or disconnect it.
Many air exchangers are controlled simply by on and off switches, but in some applications where the removal of humidity is required, then a humidistat can be used to turn the machine on and off to achieve the humidity level that you want. In cases where there may be a lot of humidity the air exchanger may not be enough to solve the problem. Other devices may be needed to lower the humidity to the level that you want.
on Dec 24, 2009 | Heating & Cooling
GE DL213908 Side by Side Refrigerator not freezing or cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Refrigerators
2005 civic ex special edition has cool air blowing out of vents in very cold weather....starts out warm but soon changes to cool and stays cool
Could be a couple things...
1. Bad Thermostat.
2. Bad Heater core.
The thermo is a easy fix if you're mechanically inclined. I would look at this first.
Feb 10, 2011 | 2005 Honda Civic
Why is my condenser freezing up, but my frig isn't cooling right? could it be the thermostat? Or is the condenser flooded?
when the evap ( the coil inside the freezer freezes up it blocks the coil causing no cold air to flow to the fresh food side. . the thermo is ok but the aditive defrost control or the heater or defrost terminator is or has failed .. mm ( you do have a defrost problem .. mm
Aug 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Runs steady, i have unplugged it for a day,no results,checked underneath and no freeze on coil,will make ice cubes in tray but breads,perogies, icecream soft couple of tubs of soup staying solid, its only...
ck for both fans going if fan in back has failed cooling will be reduced and if fan inside failed poor cooling . thermo in fresh food side is saying were not cold enough and is keeping the comp on . . also in the back of freezer ( not underneath ck for frost build up . ) any frost in a no frost would cause your problem .. mm
Dec 07, 2009 | Dishwashers
Thermo wires came loose
The panel on the side has screws in it. Remove them and remove the panel. Then to get to the control panel, you have to remove the innet sheet metal panel.
Best regards, W/D
Aug 19, 2009 | Weather King 10AJA2501AH Air Conditioner
How do I use the air exchanger open or closed for best cooling? Bought a used in window unit? Thanks.
"Closed" cools best, but does not exchange air with the outside. Humidity in the room can have more of a tendency to freeze up on the coils, but it is relatively rare. Odors also tend to build up. "Open" allows some outside air to be exchanged with the inside air, but this is less effecient.
That was the long answer. What I'd do is operate it as closed as I could stand it, and leave it cracked open a bit. If I started having icing problems, I'd open it a bit more.
Regards, --W/D--
Jul 23, 2009 | Maytag Heating & Cooling
Thermo seneor hanging in side a/c freezes up. need
If it's the probe type, insert into fins up about 3-4 inches from bottom. If disc type, look for hole in frame on left side, low ,disc fits through hole, and clips on to coil in behind there. You should be able to feel the coil with finger first, just push a little on fins.
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Dometic Rooftop RV Air Conditioner Logo
138 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
