Hi, I've got a sennheiser handheld mic and reciever. I am having problems with the RF signal on the receiver. It drops out if I move even a few feet away.All of the sensitivity and squelch settings are ok. I have tried the mic with another reciever and it works fine. Any ideas ?, any solutions ?, any advice on where to get it repaired? ThaNKS! Derek
    Sergeant:
    Champion:
  • 319 Answers
Receiver maybe out of adjustment for mic frequency band
Posted on Apr 24, 2008
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows.
RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again.
Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
RF Remote Problem
Could anything other electronics be interfering with the signal?
Aug 18, 2008 | KVH Additional M2 Or M3 St Receiver Kit...
Wireless mic not sending signal
need more information.
what model?
handheld or beltpack? microphone or instrument?
check transmitter and receiver are set to same frequency.
does a different transmitter work with the receiver?
does the receiver show the transmitter is functioning (ie receiving rf) but not receiving audio signal (af)?
Nov 07, 2013 | Sennheiser Audio Players & Recorders
Sennheiser ew g2 bodypack with shure u2 receiver compatibility: When I tune the frequencies similar to each other, the U 2 gets an RF-Signal, but it doesn`t receive any audio-signal, when i talk into...
Sorry, that will not work. Typically, it is not possible to use one manufacturers transmitter with another manufacturers receiver. The two manufacturers use different tone-key squelch, different noise reduction, and different companding schemes.
Aug 09, 2013 | Shure U2 / 87 With SM-87 Professional...
Dropped the mic.
I would imagine the mic element broke. To test, remove from the case and without touching anything else, touch (using a small screwdriver if need be) the solder connections on the wires for the mic element (while system is up). Hum? Yes? bad mic element. No? Problem with electronics. Look for broken wires also.
The receiver shows signal so RF is ok. You have a problem with the audio section.
Apr 28, 2009 | Audio Players & Recorders
Frequency clash
There are different frequencies available and being used in each location.
To get a basic idea of which frequencies are available in your area, try this online tool:
http://www.sennheiserusa.com/findfrequency/
or use the literature provided with the Sennheiser gear (usually a useful chart comes with the wireless gear).
Also, remember that your transmitting frequencies need to be spaced apart a minimum of .400 MHz (or 400 kHz).
Frequency selection shouldn't cause feedback problems though. If you select a frequency for a mic that a local TV station is already using to broadcast, it will cause RF Interference (Radio Frequency). You'll probably hear static noises, pops, or since your Sennheiser has a Squelch feature, just drop-outs in audio.
So first consult the available charts to find a set of frequencies that should be available in your area. Then, if one of your mics is experiencing such an issue, try moving it .400 MHz to the nearest unused frequency and see if the RFI goes away. Repeat until the RFI no longer manifests.
Jan 30, 2009 | Sennheiser 100/500 G2 Series Wireless...
All four hand held systems failed
check out override frecq see if you can change transmit and recieve switch settings ie dip switch sets sombodys overiding your freks
Dec 17, 2008 | Sennheiser Evolution G2 100 Series UHF...
All four hand held systems failed during a performance
Hi kb
That is an odd encounter, and most probably one of the R.F.I. kind. Radio Frequency Inference can be caused by many things. Sometimes it can be a nearby piece of equipment creating that much interference, that the mics could not operate. It may have been a spurious mobile radio transmitter as used with two way radio for the cops, ambo's, firies,or even a nearby Cab!! Some times faulty light dimmers can also spray RF.
To what ever end, the fact that 4 mics went down together is indicative of an external problem, and being radio mics, it would have been radio interference.
The only other thing to check is that they are UHF. there are many VHF mic systems still about, but these frequencies are now being used as part of the soon to be introduced digital TV transmission. Best check that they are UHF, The VHF type have actually been illegal for a number of years Hope this info has helped you understand your problem. I am happy to answer any questions you may have. Cheers
regards
robotek
Very bad hiss even when power is turned off and battery is removed
If you use a sennheiser check your Squelch is not set to high / low. I use a Z1 and that solved my problem.
Feb 07, 2008 | Sennheiser EW100ENG-G2 2-Way Radio
37 people viewed this question
 Grubhead
Grubhead
