My Goodmans Micro 14671 has a problem where the buttons on the controller and the face of the player to not work apart from power on/off and the function button which turns the player off but not on, i can change volume level and radio channels and thats about it can anyone help??????
Seems to be a common fault......
Posted on Sep 24, 2010
My remote control does not work at all
Please check for tips to check if the remote IR works and if you are able to check this out: http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Dec 14, 2011 | Goodmans Televison & Video
Goodmans micro 14671 turns off if function button pressed.
This definitely works-just done it. I pulled out the centre of a biro to get a thin plastic object. With the power on stick the plastic deep in the headphone hole and then push it in some more! Then I turned off the unit at the power button on the stereo itself. Voila-reset and listening to CD's now!
Jul 17, 2010 | Audio Players & Recorders
Power button dose not work
generally its cheaper to buy a whole new reciever than to buy just the face plate as they are not manufactured as seperate components.
Jun 19, 2010 | Clarion DXZ835MP RB AM/FM/CD/MP3/WMA...
None of my buttons work. I tried to reset it and
check connection between face and unit make sure it is clean, pull apart face and clean circut with metho(make sure it is dry before testing and see how u go this should fix it
Apr 22, 2010 | Aiwa CDC-X304 CD Player
How do you charge it?
use computer with your provided cable or use motorola charger.
Feb 24, 2010 | Creative Labs Zen Micro MP3 Player
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Goodmans car
press the volume plus button failing that try resetting it. There could be a button for mute on one of the numbers on the face
May 24, 2008 | Car Audio & Video
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
558 people viewed this question
 Grubhead
Grubhead
