Question about Kenmore Dryers
I own a Kenmore Elite c8586 dryer and I unplugged it and when I plugged it back in I lost the ability to turn off the display and it is stuck in the bedding drying option. If I press another drying option nothing happens. Ive unplugged it again and tried that but nothing happened. Any help would be appreciated
  • 11,896 Answers
When you unplugged it, did you leave it unplugged for a while. While unplugged did you press and hold the cancel or pause or stop button for 10 full seconds? That is what I recommend. If that doesn't help, the cycle timer may need to be replaced
Posted on Jul 30, 2010
Kenmore elite he3t front load washer has no power. Replaced ccu, worked for a few minutes then stopped. Unable to power up
I would guess you have a short in the machine somewhere and likely have fried the new CCU also. If you want to and have the ability, you can track down the short and fix that. Then you will probably have to purchase another CCU before it will run. Wish I had better news. Good luck.
Jun 22, 2016 | Kenmore Washing Machines
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
How do you reset the computer on kenmore elite he3t steamer
UNPLUG FROM WALL SOCKET FOR 5 MINUETS PLUG BACK IN TRY AGAIN IF YOUR DRYER IS HARD WIRED DO THE SAME AT THE FUSE OR BREAKER
Oct 30, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Have a Kenmore Elite Oasis Electric Dryer 110.67092600 that keeps beeping when it is empty and supposedly turned off. Also when we try to start it up it keeps shutting itsel***. It was purchased in January...
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from www.SEARSPARTSDIRECT.com
The procedure for replacing this control board is shown in the images below.
NOTE: You should only attempt this procedure if you are completely confident in your technical ability to safely execute the process.
Follow electrical safety guidelines. Unplug the washer before accessing internal components.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#@#$
May 19, 2010 | Kenmore 67082 Electric Dryer
Kenmore Elite Oasis Dryer
Mar 09, 2010 | Kenmore 67082 Electric Dryer
Same prolem here with the beeping. My Kenmore Elite Oasis Dryer model #110.67092600 beeps the whole cycle and drum light turns on by itslf.
Mar 08, 2010 | Kenmore 67082 Electric Dryer
I have a kenmore elite oasis he washer. it will
Mar 06, 2010 | Kenmore 73952 Gas Dryer
I have a Kenmore Elite OASIS dryer, my problem is that it spends all day all night with a one beep, and displays a one, or a two, or a three, the panel says press stop twice, and I have and it comes back....
Feb 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
