Question about Sony AIRSA20PK S-AIR iPod Dock and Digital Wireless speakers Docking Station
I bought a Sony BDV-IS1000 Home Theater system with the rear wireless S-AIR system. I can NOT get music to play out of the rear speakers. I have paired the the receiver and amp about 100X. No joke. I read other sites that everyone is having the same problem. I purchased a Monster HDMI cable and it still does not work. I talked to Sony help for a couple hours and they are sending me some signal booster thing. Does anyone else have any ideas on how to fix this thing. I have the system on a cabinet above the TV and to pair I have the sub on top of the receiver. Its as close as they get to pair. THanks
4 Suggested Answers
SOURCE: S-Sir Sub Unit won't pair
I almost went out and bought a Sony HDMI cable but I tried something first and it worked me. I wrapped tightly the transceiver on the back of the main unit with aluminum foil and what do you know it fixed the problem. I guess since I was using a cheap HDMI cable the foil helped to shield out the interference. Sony HDMI cable $70.00 or aluminum foil 5 cents.  Let me know if this works for you as well.
Brent mevioradio.com
Posted on Apr 26, 2009
jcameo7270
  • 675 Answers
SOURCE: I have an S-air wieless
The unit probably does this so that you don't have an impedance mismatch which would mess up the internal amplifier...most home stereos will do this to protect the amplifier...
Posted on Jan 01, 2011
  • 52 Answers
SOURCE: my ipod wont play through
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Posted on Nov 08, 2011
Sony N-990W region free
Actually, you can also rip your DVD from the DVD disc and then you can paly the movies at any time and any places freeky. If you want, you can find a DVD ripper to depend, here I recommend you leawo DVD Ripper, it is really good to use!
Nov 21, 2013 | Audio Players & Recorders
How can I fix the echo between my TV speakers and my dvd/blu ray player home theater speakers when watching a movie. Also, in the settings menu on the BDV E370 system do I have to select speakers only...
Easy, disable the TV speakers or turn its volume down.
http://static.highspeedbackbone.net/pdf/Sony%20BDV-E370%20Manaual.pdf
Page 36 tells you how to sync the sound to the picture but you really shouldn't have the TV speakers competing (in stereo) with the Sony. (Page 56).
A) The TV speakers are probably inferior to teh Sony's
B) When you balanced the speakers during setup there was no 'with-the-TV-speakers-on' option. The image up front would suffer by adding an unaccounted for sound source.
Aug 11, 2011 | Sony BDV-E370 Theater System
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    Sony BDV 370 home cinema system and Sony 40hx703 television. The home cinema plays disks etc. through the cinema speakers. But will not play television sound through the cinema speakers it is connected...
    You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
    Aug 29, 2010 | Sony BDVE300 Theater System
    Keep saying No Disc on Sony BDV-IS1000
    a lens dosent work. you need to buy more
    Sep 28, 2009 | Sony DAV-IS10 System
    No sound from back surround speakers
    We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
    Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
    No sound from our Sony Wireless Home Cinema System
    Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
    Jan 10, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
    Wireless speakers won't connect
    You try upgrade the main set to 5.1 or 7.1 channel is it?
    If the wireless is green light mean the main set is recognize the wireless.
    You need to setup the speaker output from main set by "Setup" button on remote control.
    Can refer Operating instruction manual in main set.
    Nov 29, 2008 | Panasonic Home Theater System System
    Sony AIRSA20PK S-AIR iPod Dock and Digital Wireless speakers  Docking Station Logo
    108 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
