Question about Hotpoint Dryers
Makes a grinding sound when in operation - Hotpoint Dryers
    President:
  • 3,773 Answers
Rear tub bearing and/or front felt bearing w/slides
Leo Ponder
imufo2@sbcglobal.net
Posted on Jul 30, 2010
Hobart sr24 dishwasher making a grinding metal on metal sound
Pump bearings, staff dropped a teaspoon down the inlet to the pump. You need a service engineer. Don't run it.
I have been in the hospitality for 45 years and seen it all. Our drain mechanism broke a month back and it was full of cocktail sticks. We just got a brand new machine.
May 18, 2016 | Hobart SR24-H Built-in Dishwasher
Scooba 385 - Making Grinding Noises - Video I
there are no parts available for these ( toys ) so called vacuum cleaners. Sorry you wasted your money.
Oct 10, 2013 | iRobot Scooba 350 Robotic Vacuum
Grinding noise with heavy load
sounds like a problem with the bearings,have it checked out by a service engineer
Dec 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Tv makes grinding sound, won't turn on, circular button at bottom of tv flashes timer lamp. when I push on it won't turn off and makes a grinding sound
Sounds like it's time to replace the projection lamp, and check to make sure the cooling fan is operating like it should, also don't forget to clean the filter for the lamp.
Check your operators manual for tips on all this, you might have to look in the troubleshooting section.
Good luck !
Jan 24, 2010 | Televison & Video
My Maytag Dryer makes a very loud grinding sound
drum main bearging is gone time to get another dryer or have that one repaired for about twice what it is worth... cheaper to buy a used one and go with that till???
Nov 18, 2009 | Maytag Dryers
My Kitchen Aid KSM150PS Artisan red mixer trembles alot and makes a grinding sound when I use it. I've exchanged it once already and have the same problem again.
Kitchenaid mixer are supposed to make a slight grinding sound while operating under load. This is simply the gears meshing together while the motor is turning them, but if the sounds gets worse or is already a metal grind type sound this could indicate a broken worm gear inside the unit, and shouldn't be run any longer. However if your mixer isnt on SOLID ground this could cause the tremble as well.Hope this helps
Thanks
Oct 31, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
