I have hooked it up to cable that is in the wall in our appartment building and I don't get a picture. Do I have to program something.
  • 115 Answers
You tv needs to have a tuner in it. A plasma or lcd MONITOR won't do, and the cable has to be enabled from the cable company.
Posted on Jul 31, 2010
Hooked game system PS3 to tv-cannot get picture or sound
What input are you trying?
Banana Pins or HDMA Cable
Nov 28, 2013 | Televison & Video
I have a Samsung hdtv but its not playing in hd.I have it hooked up to cable straight from the wall bypassing the cablebox.Is it the tv or cable?
You do not indicate if you have auto programmed the television to get digital channels, If you are selecting a channel without a decimal point, for instance 82.3 is NBC hd in my cable system. If your cable provider does not produce these on direct cable then you can not get HD without a box.
Try to Auto Program your tv in the cable mode STD format, this can take up to 20 minutes to complete scan including deleting scrambled channels. After programming try the lowest or highest analog channel like 2 or 70, channel down or up from there to see if any digital channels appear.
Mar 01, 2013 | Samsung Televison & Video
I HAVE A SONY 1999 HAS VOICE BUT DONT KNOW HOW TO HOOK UP CONVERTER ANTENNAS THAY HAVE NOW SO I HAVE NO PICTURE
Set should have up to 3 coax or cable fittings--if only one connect to it and in menu program the set with the remote.
If no cable hook up something to av audio/video jacks and select that input to use.
Try to give me better idea of what kind of signal you are using and how many connections the set has available.
Mar 13, 2012 | Sony Televison & Video
Is there a direct cable tv connection on a mx-50x5 i want to just connect my cable from the wall right to the tv?
I don't believe this tv has a tuner, so no I don't think you will be able to hook up directly to your cable from the wall. Most newer units do have a built-in tuner, tho some do not. Make sure to check the specs first.
Sep 12, 2011 | Maxent MX-50X5 Television
89 dodge dynasty starts up and dies immediately like it starving for gas, always on empty so could I have burned up the fuel pump inside the tank ? Its driving me bats to not get this diagnosed and fixed!...
The relays are probably working ok.
When you turn the key on the pump in the tank should whirl for a few seconds then stop when the fuel pressure is up to spec. If it doesn't stop, the pressure is not building up or if you don't hear it then it probably isn't pumping.
Jun 05, 2011 | 1989 Dodge Dynasty
I can't figure out how to program cable box. The cable is hooked up to the TV, but I can't find out how to get channels. Is there a certain menu or imput?
Are you getting any picture at all? check your tv's input button on the remote if your cable box is hooked up with hdmi select hdmi, if it is component video cable select component video, and if it uses a coaxial cable it should be something along the lines of tv. Push the input button on the remote to switch between the different modes
Mar 20, 2011 | JVC HD-56FN97 56" Television
I PROGRAM A REMOTE TO TV NOW I CANT GET IT TO TURN OFF SO I UNLPUG IT FROM THE WALL. NOW AFTER PLUGING IT BACK INTO THE WALL I CANT GET A PICTURE ALL I GET IS A BLUE POWER LIGHT
you seem to have the incorrect code to the tv this is not allowing you to turn the unit on try the main override switch at the side. appart from this you will need to keep scanning until you get the correct code
let me know if you need further help
sonic boom electronics australia
Jan 04, 2011 | Polaroid TLA-04011C 40 in. LCD TV
I have a comcast digital converter box and i need the manual to hook it up to a tv
Here is the easiest way...
1. Connect coax cable from the wall to the "Cable in" on the cable box.
2. Connect a coax cable from the back of the TV to the "To TV" output on the back of the cable box.
3. Tune your TV to channel 3
4. Plug the power cord into the back of the cable box and into a power outlet.
5. If you do not have a picture call Comcast and ask them to send a signal to activate your new box.
6. Enjoy your new programming.....
Good Luck...
Jan 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Dell flat panel monitor
It's a problem in the power supply section inside the monitor. It needs component-level electronic troubleshoting.
Jan 16, 2007 | Kogi l4bx-na ko 14.1" Flat Panel LCD...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
