Question about Toshiba TDP-T30U Multimedia Projector
Tdp-t30u unit turns on then after 2 min goes to stanby. Fan light
Tdp-t30u unit turns on then after 2 min goes to stanby mode. fanns are on high and the fan light flashes green power light steady red. is it worth fixing. what could be wrong and how much to fix.
  • 10,594 Answers
In service manual, fan light flashes green power light steady red is an error code that shows Device Error and possible problem is defective Main Board or AF board in projector.
Both boards will only be available in Toshiba service center and of course cost you around new projector price. New projector is better choice instead of fixing this one.
Let me know if you have additional question.
Thanks.
Posted on Jul 30, 2010
Heater a/c control unit not working
what mode, heat or cold?
does fan blow?> no "? then replace the fan fuse.
fan blows on high? yes.
then if A/C ? wanted? why not say? then the green light glows
near A/C switch, does it? y/n
yes the does A/C compressor clutch close? and compressor shaft turn? y/n.?
or its heat you want? not stated.
so no heat, is a whole other list. ill try.
1: engine not hot, not 180f min. and holding (y/n)
2: cab fan dead.
3: heater core not hot, (feel the hose there both must be hot)
4: damper stuck closed blocking heater core.
Mar 25, 2014 | 1996 Geo Metro
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
How do I check the bulb hours on a TOSHIBA TDP-S26 PROJECTOR?
I found a similar issue with another brand/type of projector and used that solution. It worked!
Mar 23, 2009 | Toshiba TDP-T30U Multimedia Projector
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
Won't turn on
What worked to fix this projector when it wouldn't light..
Sep 02, 2008 | Toshiba TDP-S8 Multimedia Projector
Power Failure, How serious a problem and cost?
Hi there
You will either be replacing the Main Power Board or the Ballast Board ( Lamp's powersupply ) The symtoms you described sounds like a faulty Ballast.
Both of the above parts are fairly cheap to replace.
Mar 25, 2008 | Toshiba TDP-T30U Multimedia Projector
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
Toshiba TDP-T30U Multimedia Projector Logo
55 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
