Question about SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal
My hard drive seems to be cutting in and out - works for a bit, then computer reports it as disconnected, then it comes on again. Light is on throughout
  • SimpleTech Master
  • 27,725 Answers
Sounds like a loose connection of some sorts test all connections from motherboard to hard drive also electrical leads to motherboard and hard drive and IDE,SATA leads Maybe a faulty PSU so test that to
hope this helps
Posted on Jul 31, 2010
How can I be sure if my PCM is bad???
I would try disconnecting battery again. Disconnect both cables and touch them together for a few seconds. This will reset all modules. Wierd that you had so many codes after just disconnecting battery. Sometimes very hard to tell if ecm is bad.
Dec 01, 2014 | 2006 Pontiac Torrent
Will a bad fuel filter cause the engine light to come on
Yes it will, Not because of the fuel filer itself but from the lack of fuel pressure causes other problems. Replace the filter and see what happens.
There also is a tank sock filter but it is usually NEVER it.
Hope this helps MIke
Apr 28, 2017 | 1998 Ford Explorer
Power Light comes on, no function what so ever
Check to make sure that the FireWire or USB cables are
correctly attached and firmly seated in both the drive and
computer's FireWire or USB ports. Disconnect them, wait 30
seconds, and reconnect them. If the drive is still not
recognized, restart your computer and try again. If they are
correctly connected and your drive still does not power on,
trying using the optional power sharing cable, described in
section 2.3 Connecting the Optional Power Supply of the LaCie Mobile Hard Drive User Manual.
Feb 17, 2013 | LaCie Computers & Internet
My drive has been working perfectly with my PC for a couple of years, it's about 75% full. Last night I attached it to a different laptop and it worked fine there. When I reconnected to the original PC...
Try to scan your Had Drive with updated anti virus it may attacked by a virus. Connect it again where the hard drive is working fine. I have some clarification if you disconnect it properly in the computer where you have the time you use it. Because if you disconnect it in your PC without proper procedure it may possible cause of corrupting you files inside you hard drive or internal damage to your hard drive.
Jul 19, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
Flat screen monitor functioning strangely
Sounds like there maybe bad caps on the power board in the LCD. Try a different monitor on your computer and if the known working monitor comes on with the computer and behaves properly then you know its a problem with your original monitor. If the known working monitor acts strange as well then you know its a problem with the video card. Let me know what happens.
Jun 11, 2009 | E-Machines eMachines Desktop PC
Thinks it's full
232 gbs is normal, a 250 GB hard drive has generally less space than 250 GBs, the actual size of the disk depends on the way used to format it.
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Light doesn't turn blue at all
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Mar 31, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal Logo
61 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
