Question about Polaroid FLM-3201 Television
All outputs 0.0V DC except 5V output is 0.6VDC. this condition exists whether or not any loads are connected. So far I have not been able to locate a replacement except from Polaroid at their inflated price.
  • 11,361 Answers
Can I tap a -5v into a BESTEC atx-250-12z-rev d2 power supply ?
The output from the power supply is
Output Max. Load +5Vsb 2A -12V 0.3A +12V 13A +5V 30A -5V 0.3A +3.3V 20A Pin 18 out of 20 white -5 volts (optional)
20 out of 24 white -5 volts (optional) See the definitive connector definition.
All about the various PC power supply cables and connectors
Mar 05, 2015 | Computers & Internet
Where can I find the user manual?
This sounds like a battery or iphone charger. Need more information to confirm.
Nov 17, 2014 | Computers & Internet
What do they mean the input voltage range between the wall outlet and this adapter is ac 100v-240v, and the adapter's output voltage is DC 5V,2A
A lot of new computer hardware will accept regular 110-115v like most people have in their homes (USA) or high voltage 220 (mostly used for washer / dryers) or industrial use. Like in a factory. This unit accept both without worries of over loading. Some may even have a switch to swap back and forth. It actually only uses 5v and 2amps. Meaning a single 110-115 power strip can handle many plugs, because of the low voltage.
Aug 28, 2012 | ASUS Google Nexus 7 16GB Tablet 71B16
Micromax x225 is showing low signal
Ever looked at the power specifications of a mobile charger?? well if not, then have a peek... u will read that the output voltage is 5V DC........ the computer USB also has a voltage output of 5V DC........... any USB based electronic device needs this power to get started.... The laptop coolers u get basically work on this power from the USB... U'll notice that the USB ports have 4 terminals.... the extreme outer side are the POWER terminals +ve and -ve..... the middle 2 are the BUS lines IN and OUT.... a BUS is something electric conductive that allows the flow of 0's and 1's or rather high and low voltages to pass(Basic IT theory).... so this 5V DC can be used for doing anything; charging the mobile phone battery to lighting up entire rooms with LED's, making laptop coolers, etc......... Every mobile phone which has the USB connectivity option gets charged when plugged in... so sometimes even if u dont have the Mobile charger dont panic, find a computer and plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which charge by connecting it to pc. Only nokia phones don't get charged. it is a good feature don't worry
Feb 24, 2012 | Nokia Cell Phones
The new adapter is not compatible with the battery more info: laptop-batteries.com.au
you will need a genuine dell charger and look on your old one to see what pa it is if it says pa-12 then you need the same one again
Feb 22, 2011 | Dell Inspiron E1705 Notebook
Connecting a Heath Zenith Doorbell 172C-A
Do you have a transformer with it? Apparently this doorbell can operate on AC or DC (3-6VDC or 8-16VAC). The usual method is to supply 110 VAC to a transformer with an output of about 16VAC. ------ BE SURE YOU KNOW WHAT YOU ARE DOING WHEN DEALING WITH 110VAC. HAVE A CAPABLE ADULT HELP YOU WITH THIS! ------- Connect one of the two outputs from the transformer to one of the terminals on the bell (this might be labeled COMMON) The other output from the transformer will go to your handheld lead (like in the Operation game). Connect a lead from your patient (as in the Operations game) to a terminal on the bell which is probably labeled for AC.
Apr 22, 2010 | Heath Zenith Electrical Supplies
I have a smartlink ESK-108 with no power supply can you tell me what voltage is required thanks?
AC/DC power adapter transformer
AD-051A 120v 13W input AC, 5v 1A output
or
JOD-41U-27 120v 100mA input AC, 5v 1A output
I have the latter and it works.
Apr 12, 2009 | Archtek America ESK-108 8x10/100 Mbps...
Intermittend no audio from digital inputs, flicker video monitor out, volume goes up but not down
Since the problem appears only after the unit has been run for a while, I'd be looking for any part close to a heat source. The odd behavior suggests that there is noise on the data lines for the volume control chip and the digital processing areas. Look for a bad 5V regulator +/or bad caps on the 5V line. Also check for poor solder connections in the power supply and final output stages.
Keep us posted.
Dan
May 13, 2008 | NAD T762 Receiver
Polaroid FLM-3201 Television Logo
151 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
