Question about Poulan "Poulan" Push Mower
I just bought a Poulan PR550N21RH3 Rotary Lawn Mower. The first time I used it it worked fine. While I was mowing the second time I heard a big "POP" then it began to shimmy. What should I do?
  • 755 Answers
Check the blade to make sure its on securely and isnt bent or broken.
If something went wrong other than blade damage I would take it back and ask for a replacement.
Posted on Jul 30, 2010
Hi I bought a second hand model of this lawn mower yesterday
the wire and brass contact of the kill switch
governor adjustment
idle adjustment
spark plug
coil
carby bowl drain and check contents clean
Oct 19, 2016 | Garden
Lawn mower will not start after running out of gas.
are you getting spark?was the gas you put in newer than 30 days old?
Jul 22, 2012 | Poulan Garden
I hit rocks with my lawn mower on accident, and now it will run for a few seconds and turn off
This happens often. Sometimes your mower will start and run again and sometimes it won't. When it doesn't run it's because your timing is off, caused by a dented or sheared key.
To replace remove top cover to engine, and any other side attachments, this should expose the flywheel. Remove the top bolt and look between flywheel and top of crankshaft, you will see a small square notch. This is where the shear key is placed. Remove the flywheel and replace the shear key. Replace all parts in reverse order and you should be mowing again. GOOD LUCK.
Aug 31, 2011 | Poulan "Poulan" Push Mower
The engine is not started
Hi.
Check the blade... it is bent and causes a vibration. if it is not the blade then the motor shaft is bent and that is terminal...if that happened then the mower is junk...
heatman101
Jul 12, 2010 | Poulan "Poulan" Push Mower
It won't keep going.
Remove and clean out the carburettor, its dirty and full of old dead fuel.
Apr 25, 2010 | Poulan "Poulan" Push Mower
New Poulan gas mower blowing white smoke
if its new carry itback theres a number of things it could be but it sounds like the crankcase is full of gas check the oil and see if theres gas in it.
Oct 25, 2009 | Toro Lawn Mower With Toro Power Tools
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
LOOKING FORWARD TO PURCHASING A POULAN RIDING LAWNMOWER. AS A FEMAALE I AM A BIT APPREHENSIVE ABOUT A RIDING LAWN MOWER. I HAVE USED A SELF-PROPELLED FOR ABOUT 30 YEARS. AM I MAKING A GOOD CHOICE?
If you like driving cars, riding 4 wheelers, or just plain love the outdoors, the a rider is definately the way to go! Everyone loves the joy of a riding mower no matter what age. You will definately will fall in love with cutting your lawn. Use the rider for the big stuff and push mow the little hard to get places.
Jul 22, 2009 | Garden
Carburetor adjustment
it would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
Jun 24, 2009 | Poulan "Poulan" Push Mower
Poulan "Poulan" Push Mower Logo
160 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
