Question about SYMA Toys industrial New Syma S107 Mini Indoor Gyro
Syma s107 take off problem
Battery fully charged, syma s107's rotors spin but doesn't take off, trim adjust makes no difference. any ideas?
The blades could be on up-side-down or The battery may not be holding enough of a charge anymore. If it's the battery, check out these Syma S107 Battery replacement instructions.
Posted on Sep 16, 2010
  • Darthmonk Jan 10, 2011
    You sound as if the blades are slipping on the main shaft-found this site might helphttp://syma107.com/syma-s107-repairs/
  • Kizza Hi
    Kizza Hi Feb 16, 2014
    my syma s33 helicopter will not take off the back blade dont spin both top and bottom blades spin but dont take off need help
Syma s107 hit a dangling string that got tied up instantly and seized the rotors. now lights up but blades don't spin when throttled. What can I do besides replace the helicopter?
I was flying my syma s800g and hit the ceiling fan chain. When I attempted to fly it would spin and fall over. The problem was I broke the two small plastic pins on the top rotor holder. Ordered a new top rotor and flies fine. Then on my s107 I flew into a door and the top rotor had zero spin although the motors worked. In that case the screw that sets the top rotor onto the middle shaft loosened resulting in no lift and also tilted and fell over. This was fixed by securing the set screw properly. So in both instances it was similar effects due to the top rotors not spinning in sync with lower blades.
Jun 03, 2012 | SYMA Toys industrial Syma S032 Ready to...
My heli takes off and will slowly begin to make large circles spinning out of control.
TRY ADJUSTING THE TRIM ON THE TAIL ROTOR AS THIS IS WHAT KEEPS IT FROM SPINNING
HOPE THIS HELPS
Aug 21, 2011 | SYMA Toys industrial New Syma S107 Radio...
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
Mar 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
My sons S107 lower rotors would not turn. I disassembled and solved a gearing problem. At this time a wire came loose that supplies power to the tiny little prop at the tail. I fixed this problem too. ...
Check if s107 is fully charged.
Both rotors (lower and upper blade) should be working at full capacity. If either one of them is going slower, S107 won't lift up from the ground.
Check that gears are not too tight on each other. They should be able to rotate (leave cca 1mm space up/down between them)
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
Syma 107 I no longe get lift, have replaced batteries and have charged from usb cable. still not luck, how long do the li poly batteries last ?
About 5 minutes.
Check if gears are not too tight together.
If it's OK, then one rotor is working slower than the other one, and because of that, S107 can't lift off ground.
Feb 27, 2011 | SYMA Toys industrial New Syma S107 Radio...
My heli dosent have any lift it is fully charged and I give it full throttle and it get about 2 inches off the ground and that's it caint figure it out and iv only used it about 5 times
Check if gears are not too tight together. There should be little space (up/down) between them (cca
If that is OK, then one rotor is working slower than the other one and should be replaced.
Which one? When S107 is flying on the ground, check in which direction is it spinning.
You should replace rotor responsible for spinning in other direction.
Feb 26, 2011 | SYMA Toys industrial New Syma S107 Radio...
Hi, my syma s107 worked great for many flights,still has about 7 minute flight time but not getting any altitude.thinking motor wear? any suggestions.thanks
Very important with these motors and the batteries is a solid 5-10 minute rest after charging and after flying. Make sure the shaft is fully seated. Push it down firmly (but gently) both above and below bottom rotor.
Let me know if this doesn't help.
PvT
Jan 21, 2011 | SYMA Toys industrial New Syma S107 Mini...
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
The top rotor of my syma S107 is not working and the motor is making a different sound. What should I do?
This is a counter rotational craft and thus there should be two electric engines turning one rotor each. The top rotor is probably connected to the lover gear, and thus this is where you should start looking.
When you turn your top rotor, do any of the gears move? Try holding the gear while turning the rotor also, if the rotor is spin able while holding the gear then your rotor shaft is damaged and the entire rotor should be replaced if possible.
Also, try turning both rotors and see if one spins heavier than the other. This should
also indicate damage to the construction, or the engine.
If everything is looking all right, and all the gears turns all the way to the engine, and everything looks tight, then it is a great possibility your engine is fried.
Many of the sets have easily changeable rotors and rotor shafts, and some also have easily changeable gears. However, most cheap crafts like this do not have easily changeable engines. I do not know this model, so this you have to investigate. Now, it is possible to do engine shifts by yourself even if the manufacturer does not provide spare parts, but I
Dec 23, 2010 | SYMA Toys industrial New Syma S107 Mini...
My syma s107 will not lift off the ground
Assuming the battery is fully charged, the shaft could be dry, purchase a WD-40 pen, they have a magic marker type tip that dispenses controlled amounts of lube by pressing the tip on a surface to get a drop then use a toothpick to put a small amount on the rotor shaft top and bottom. I did that to mine and the shaft spins a lot smoother. Mine always lifted off with no problem, but it got the gitters and and would drop a few feet now and then. after I oiled the shaft the gitters went away. Give it a try. John.
Dec 05, 2010 | SYMA Toys industrial New Syma S107 Radio...
SYMA Toys industrial New Syma S107 Mini Indoor Gyro Logo
4,976 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
