Question about Husqvarna Saws
Wrong fuel used in cut off saw ,husqvarna - Husqvarna Saws
    President:
  • 1,857 Answers
Plain and simple. its either damaged or not damaged, put the correct fuel in it and hope for the best. Plan on rebuilding the top end if it is damaged. No other options availiable
Posted on Jul 30, 2010
New plug, use up one tank of fuel, refuel and saw will no longer start. Plug deposits are white. Put in new plug and will run. Tree cutting, not brush so running hard. Any thoughts?
If you're cutting pine (and more so if your chain is a bit dull and tending to make more dust than chips) you may well have plugged the air filter with resin.
Jul 27, 2016 | Husqvarna 240 18" 38.2cc Gas Powered Chain...
Wot is the fuel mix for a partner k 750 disc cutter
50-1 with Husqvarna two stroke oil, but 25-1 with other two stroke oil as the quaility is unknown, always try to use Husqvarna two stroke oil
Mar 09, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I have a Husqvarna 357 xp which is about a year and a half old, but has had very little use for a professional saw. I was cutting with the saw upside down when it suddenly cut out. After letting it rest...
The carb is an "all position" type and shouldn't be the problem.
Check and clean/replace the fuel filter in the tank. Dirty or old gas, sawdust and/or water etc. settle on the bottom of the tank; and when the saw is turned over will plug the filter, causing the symptoms you discribe.
It is possible, if you used old gas(3 to 6 months) that small varnish particles have gotten through the fuel filter and have pluged the fine screen in the carb(located under the diaphram).
Sep 22, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Husqvarna 350- stopped while cutting
very straight forward to remove carb and take apart. replacing the fuel ines is a good idea. using compressed air is the best way to clean carby.
May 05, 2010 | Husqvarna 450 e-series 18" Chain Saw
Saw starts but engine cuts out after less then one
i think you really need fresh fuel, clean out tank as much as poss with new oil also. will probably take a while to pump fuel through
Mar 06, 2010 | Husqvarna 450 e-series 18" Chain Saw
262 XP engine cut out on tickover, now will not start
Try checking for spark when she won't start. I'll wager your ignition module quits when it gets good and warm. HTH
Lou
Sep 28, 2009 | Husqvarna Garden
I have a husqvarna 350 chainsaw, it wont cut straight throuh a log without cutting at an angle and getting jamed. what is the problem , any sharpening tips
THE ONLY THING THAT CAUSES A SAW TO CUT ON A CURVE IS THE CHAIN IS SHARPER ON ONE SIDE THEN THE OTHER AND IT PULLS THE SAW CHAIN TO ONE SIDE CAUSING THIS PROBLEM.
THERE IS NOTHING WRONG WITH THE SAW, IF YOU USE A FILE TRY A FILE GUIDE THEY WORK GREAT
Sep 17, 2009 | Husqvarna Garden
My partner 700 cut off saw's carburetor keeps loading up with gas.
you may have a hole in the fuel pump diaphragm,in the carb. Which will let gas into the crankcase through the pulse line
Aug 18, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
Saws Logo
102 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rlev_7
Level 1 Expert
sgtstrat
Level 1 Expert
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
