Question about Maytag Dryers
The drum tuns but there is no heat for drying. what can cause this problem? is there an electrical schematic available?
    President:
  • 3,773 Answers
Check breaker for 220v. It will run on 110 but not heat
Posted on Jul 30, 2010
Dryer will not shut off and not heat only way to keep is to leave door open
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Apr 25, 2016 | Dryers
What is fault code 6 mean?
Hi Darrell, The link below is about how to trouble shoot and fix your dryer.....I hope this helps.....CHEERS..
http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
The most common causes for an electric or gas dryer to stop drying or heating is:
1. The dryer lint screen (lint trap) has not been cleaned (poor or restricted airflow).
2. A clogged or kinked (bent) dryer air vent hose (inadequate or no airflow).
3. Drum has stopped turning, broken drum drive belt.
4. Overheated or bad motor (possible thermal overload).
5. Thermal fuse or thermostat (could be caused from dryer air vent hose lint buildup)
6. Heating element burnt out.
7. Loose electrical plug or power socket.
8. Other mechanical issue, fault or malfunction.
Mar 31, 2016 | Fisher and Paykel DGGX2 Dryer
Roper dryer works on high heat only
DID U CHECK THE HI LIMIT AND THE CYCLING THERMOSTAT? AS WELL AS THE MOISTER SENSOR?
Dryer venting issues slow drying, fire flare ups, to hot, noise and clothes ripping etc
A lint filter that is full of lint will restrict airflow and lengthen dry times.
A blower wheel that is not firmly attached to the drive motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat may trip and turn off the heat circuit.
In gas dryers, defective gas valve coils can create a symptom of taking too long to dry if they are intermittent. Check for proper flame ignition for the complete dry cycle to determine if this may be the cause.
The drum seals are used to prevent excess air from entering the dryer drum and act as a cushion between the drum and the front and rear bulkheads. The drum seals are made up of a felt like material. If the seal is torn or is worn then clothing can become stuck in the gap when the drum is turning. This can produce a scraping or thumping noise and the clothes can also be ripped and/or have black marks on them.
DOOR SEAL When the door is closed in gas and electric dryers the door seal helps to keep cooler air from entering the drum.
The vent tube or line itself. If it is kinked, smashed, to long, or filled, clogged with lint build up it can not only cause slow dry times but create a fire safety hazard. Try to stay away from using plastic or flimsy cellophane venting, aluminum is best!
To provide better air flow and heat dissipation try the following
Note the length of your dryer vent is a determining factor in how efficient your dryer will perform. If the total length of your pipe exceeds 25 feet then your dryer simply won't be able to perform as should, especially if your pipe runs vertically and through the roof. This is where a booster fan is sometimes needed. Booster Fans provide the extra push of air to exhaust the moisture and lint to the outside. These fans operate only when the dryer is activated, this is done by sensing the air flow through the pipe by a pressure switch mechanism or an electrical sensing relay which in turn activates the booster fan blower. I personally try to avoid adding booster fans simply because they are usually placed in a crawl space or attic and are therefore "Out of sight and out of mind." What I mean is... the unit could malfunction and you would never be aware of it. The result would be a restriction in the pipe which would cause a build up of lint at the fan. In addition, it's recommended that lint traps be placed before the fan itself which has to be cleaned out frequently. These can also easily be overlooked.
Mar 28, 2016 | Roper Dryers
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
My whirlpool dryer model ler8620pw0 does not shut off in the automatic cycle, but does in the timed cycle. what would cause this?
Jul 25, 2014 | Whirlpool Dryers
Drum goes around but no heat clothes do not get
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Maytag MED5600TQ Electric Dryer
Why won't my dryer heat up and dry clothes. The light comes on and the drum turns, but no heat comes from the dryer. It is a gas dryer and there is gas available. The settings are in the same cycles I've...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 01, 2010 | Whirlpool LGR7646E Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
The drum rotates, but no heat, it's an Amana Electric dryer, and it just stopped getting hot... bummer HELP!!!!!!! Fixme
You may need to replace the heating rod. Go to the website of the manufacturer and see if there are any recalls or facts that others have contributed about your dryer.
When a dryer isn't getting hot it mean that either the electricity isn't getting to the heating tool or the heating tool is broken. Look for some schematics if you'd like. Find out where the parts are inside and what goes to what.
I also mentioned the lint filter before. You must make sure the lint filter is cleaned after every drying cycle or the machine will overheat and if there is a fuse between the electricity and the heating rod you may be able to just change that! Good luck.
Feb 19, 2010 | Amana DLE330RAW Electric Dryer
My dryer turns but has no heat tuns on ok all lights come on . but when it is on sensor dry it will only run for 2 to 5 minutes and shut off. it has no heat at all
Probably burned out heating element located behind the drum assembly. Usually major tear down to get to it. If you are trying do this make sure to pull the power plug out of it's socket.
Jul 10, 2009 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
