Question about Kenmore Dryers
Temperature not high enough - Kenmore Dryers
    President:
  • 3,773 Answers
Either the thermostat or the element could have burned out in the middle and one end of the element could fall down and grounded itself to the element case which causes the element to operate at reduced heat.Partial element only works.
Check your vent too
imufo2
imufo2@sbcglobal.net
Posted on Jul 30, 2010
Why does my Tp Link M5350 3G wifi turn on and off?
When ”high temperature” shows on the OLED screen, the device is too hot, so place it in a cool, ventilated location. When the temperature is high enough, the device will stop charging/functioning in order to avoid damage.
This device responds to overheating whether or not it is charging.
When the device is charging:
• The device is powered on. When the temperature is higher than 113°F/45°C but lower than 140°F/60°C, it will not show “high temperature” but it will stop charging.
• The device is powered on. When the temperature is higher than 140°F/60°C, it will power off & stop charging. Also the OLED screen will show ”high temperature” at that time.
• The device is powered off. When the temperature is higher than 113°F/45°C, it will stop charging & the OLED screen will show ”high temperature."
When the device isn’t charging:
• Only when the temperature is higher than 140°F/60°C, will the OLED screen show “high temperature” & this device will power off.
May 04, 2015 | Computers & Internet
Tip
Condensing Gas Boilers - The Best Radiant Heat Boiler
The right condensing gas boiler coupled with the right heat transfer system to get the heat into your home the right way will give you the most efficient heating system possible with today’s technologies. There are a few things that need to be taken into consideration for this combination to work well and serve you well.
For this type of heating system to work you first need to have a radiant heat system that will supply enough BTU’s to your home at very low water temperatures. By low I mean under 100F. To get the output that you need at this low a temperature you of ten will need to design the radiant heat system with heat transfer plates. The heat transfer plates will make the transfer of the heat from the tubing that the water flows in to the floor as efficient as possible. Getting the floor warm enough to heat your house with low water temperatures should be the goal.
Now that you have a great heat transfer system you can set up your boiler to run at very low temperatures also. Most of today’s condensing boilers use out door reset technology to assist in keeping the water temperature just high enough to help the heat transfer plates produce just enough heat to keep you warm. On the coldest day of the year you want your water temperature to be no more than 100F and still be keeping your house to the temperature that you want it to be.
A great high efficiency heating system coupled with a good high quality condensing gas boiler will give the best in comfort, quiet heating at the lowest cost possible. Sure this type of system will have a bit higher upfront cost. And the contractor that you hire to install this type of heating system may require a higher rate to perform the work, But once you experience the comfort and efficiency of a top notch heating system like this you will soon forget the money and enjoy your nice warm comfortable home.
on Dec 06, 2009 | Heating & Cooling
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
On my 1996 ss impala what low side pressure should I see on the a/c with the system running
It all depends on the outside (ambient) air temperature. Your A/C low pressure switch is designed to turn the compressor off at 24 Psi. and turn it back on at 45 Psi. Most systems will normally run at between 25 and 40 Psi when the system is running on HIGH blower and "MAX" or "RECIRCULATE". A system that is fully charged may run at 25 Psi when the ambient temperature is 75 Deg. (F) and may run at 40 Psi when the ambient temperature is at 90 Deg. (F). (it can be even higher if ambient temperatures are higher than 90 Degrees.)
To properly diagnose a malfunctioning A/C system, the HIGH side pressure must also be checked. Restrictions in the system can make the low side pressure look normal while the high side pressure is high enough to blow hoses apart. (400+ Psi.)
Sep 04, 2011 | 1996 Chevrolet Impala SS
JGBP33 Get an F2 Error, oven gets warm but not hot enough to cook, will cook on broiler mode? Any help would appreciated.
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F
Look for welded relay contacts. If this happens, replace oven control (also
If no over temperature condition occurred:
Look for a high resistance connection or any other cause of high resistance in
the oven temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
defective. Check door lock switches.
measures resistance of sensor circuit , not actual oven
temperature.
Feb 06, 2011 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
Freezer runs continuously
Hello there:
Not enough informations to make the final solution. First of all what is the setting on both thermostate. They should be setting in the middle point. Not too low and not too high. Too low the unit will not be cold enough, too high the unit will be running all day long try to get to the temperature that you set for. So check your temperature setting first . Good luck and have a nice day, Dickson
Nov 04, 2010 | Refrigerators
Code 010-327
These are the possible codes and the reason for occurence of this code in your copier
010-150, 155 -Too much or not enough paper in duplex tray
010-300 --Fuser thermistor, 010-302 --Low fuser temperature , 010-304-- Bad fuser temp, 010-308 --High fuser temperature or open thermistor, 010-310 --High fuser temperature , 010-312 --Fuser not up to temperature after energy save, 010-314 --Fuser problem , 010-320 --Fuser web finished , 010-330,327, 335, 340-- Exit switch, vertical sensor switch actuated when power is turned on
Thank you!!
May 18, 2010 | Xerox CopyCentre C123 Black and White...
XEROX WORKCENTRE 5222/5225/5230 A FAULT OR ERROR FAULT CODE 010-327
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Sep 03, 2009 | Office Equipment & Supplies
Zanussi ZNB 3450S Fridge Freezer not cold enough
it is going into defrost,not enough frozen items in freezer to hold temperature down. if you bought it july last year.it should still be under waranty
Feb 27, 2008 | Refrigerators
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
