I installed windows xp program on someone's computer over a year ago. now the sound doesn't work . the device driver says the device works properly but when i try to turn up the volume in control panel the volume bar won't slide. is it my fault or is it something that that someone else did ?
  • David Dahwud Hughes Jul 30, 2010
    thank u , my friend. I'll let you know how it goes.
  • 4,737 Answers
This isn't a big issue, you'll be able to make it work after reinstalling the sound drivers. It's not your or his/her fault. First of all, uninstall the sound drivers, run a registry cleaner (click here to download). Download and install the program, and then run the registry cleaner by clicking "Registry" > "Scan for issues" > "Fix selected issues" (you'll see the progress bar detecting the registry issues in the system) > "No" > "Fix selected issues" > "Close".
[don't run the "Cleaner" after it's downloaded and installed, run only the registry cleaner after clicking the "Registry" menu. It's also important to run the cleaner, but you'll loose everything that you have downloaded in your Internet Explorer's Download Folder, if you can move them to other directories or to another folder, there's no problem running the cleaner, it's better if you can run it].
After you've fixed the registry issues and cleaned the system using the Software, restart you computer and reinstall the Sound Drivers, that'll definitely fix the sound problem. If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Jul 30, 2010
I have formate my pc & re install windows xp & there drivers. but sound driver not working properly ( no sound response ). so please suggest what sound driver compatible this device.
Microsoft windows Xp doesn't use the correct driver for your on board audio so your better off downloading Unknown Device Identifier from download.com its free and will tell you exactly what model and brand audio you have so you can find the right driver.... I had to do this a few years back with the same chipset. Good Luck
Oct 13, 2013 | VIA Vt8237r Plus South Bridge
The window media player is not working
reinstall your sound card driver. you can find driver software on mother board cd. or you can download it from net if you know your motherboard model.
Nov 16, 2011 | Microsoft Windows XP Professional for PC
Sound
check your speaker first..
in your control panel>sound and audio device driver.
or in the leftside of the sidebar, if you can see the speaker icon there click it, and make sure that it is not in mute.
Or maybe your Sound Device was broken.. update your sound device driver
or install your sound driver that is compatible with your motherboard..
Or if your sound device is built in, and not functioning
You need to install a sound card in your motherboard.. it works
Jun 27, 2011 | Microsoft Windows XP Professional
It asking for modem device on high definition audio bus driver and sound is not coming...
  • 1
    Click the link "hp: Modem Driver Installer for Microsoft Windows XP (32-bit)" listed in Resources if you run the Windows XP operating system on an HP computer; for Windows installed on a Toshiba computer, go to Step 3. For all other types of computers running Windows, go to Step 4.
  • 2
    Click "Download" from the HP website and click "Run" to install the high-definition audio (HDA) modem driver package. If the modem device does not work properly after the driver has been installed on your Windows XP computer, go to Step 9.
  • 3
    Click the link "Toshiba Audio Drivers" if you run Windows and use a Toshiba computer. Find your operating system, click the appropriate driver listed and then read the installation instructions on the screen to download the driver. If the modem device does not work properly after the driver has been installed, go to Step 9.
  • 4
    Click the "Start" button and click "Control Panel."
  • 5
    Click "System and Security" and click "Device Manager" under "System."
  • 6
    Click "System Devices" and right-click the "Microsoft UAA Bus Driver for High Definition Audio" device.
  • 7
    Click "Update Driver."
  • 8
    Update the "PCI" description drivers (PCI bus and PCI device) and any modem device that displays an exclamation point to the left of it. If the modem device does not work properly after the driver has been updated, go to the next step.
  • 9
    Visit the computer hardware or operating system manufacturer's website for further support
  • Jun 13, 2011 | Computers & Internet
    Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not...
    this problem happens when sound driver is nt installed or nt installed properly
    in this case if the driver is installed then uninstall it from control panel restart pc and then install the driver again
    after istalling driver restart ur pc
    this will definitely work
    and if not then uninstall driver restart pc
    right click on my computer
    then on properties - hardware tab - device manager
    check out here any device marked by yellow icon right click on it and then select install or update driver and new hardware wizard opens select install from internet and thats all ur problem will be solved
    Mar 31, 2010 | Microsoft Windows XP Home Edition
    Sound doesnt work in XP sp2
    i had the same problem , i downloaded this and unpacked it in a new foler on my desktop and ran etup. then rebooted computer and i now can hear again!! sound works great!! driver scan tools!!! good luck!! richie
    http://download.cnet.com/VIA-Vinyl-AC-97-Codec-Combo-Driver/3000-2120_4-10163027.html
    May 17, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
    No sound card?
    Computer sound. Check if speakers are working at another computer.. If so check that speakers mini jack are connected in right socket.(a dot with 3 brackets at 2 sides.) , should be a green socket fitted in a green female socket.. Still no sound install drivers and software that comes with motherboard, usually work 99%. There?s specific files needed for functionality depending on sound software that windows doesn?t have. If still no sound go to control panel, system,, hardware, device manager, sound video game controllers and uninstall all sound drivers. Reboot and let windows pickup up onboard sound and install drivers auto. if still no sound reinstall windows, make sure you?re not selecting new or format your hard drive, Ask someone that has done it before. This solves usually all my problems. If still no sound buy a separate souncard, they are cheap and use the disk that?s supplied.
    Nov 11, 2008 | Adaptec AHA-2944 (AHA2944)
    Sound device not working
    Windows XP
    START - My Computer (RIGHT CLICK) - Properties - Hardware Tab - Device Manager button - click on the sound, video and game controllers - on the drop down menu you should see sound codec - either right click and UPDATE DRIVER - or delete sound codec’s and restart, XP will install suitable sound drivers.
    If that doesn’t work then try installing sound drivers from the computer manufacturer.
    If you have a big X on the sound codec or your third party drivers than it’s a hardware issue.
    If replacing the drivers’ doesn’t work then it's a hardware issue. If you have onboard sound card then you will need to replace the mother board. I hope it's under warranty.
    Jun 29, 2008 | Computers & Internet
    Sound problem
    Windows XP questions and answers CH000647, How do I install Microsoft Windows XP. CH000661, How to clear Microsoft Windows ... CH000857, How do I play a sound or music file in Windows?
    Installing a computer sound card. Use this software to install the card into the computer. Sound card drivers can be found on our sound card driver page. If you do not know the manufacturer.
    Device Manager information and help CODE 24 - Device not Found, This device is either missing or not working properly. Verify you have the latest driver installed for your device.
    Good Luck, Please dont for get to Vote/Thank You.
    Dec 22, 2007 | Toshiba Satellite 4300 Notebook
    Computers & Internet Logo
    18 people viewed this question
    Alun Cox
    David Payne
    David Payne
