Question about Frigidaire Freezers
No problem I just wonder why the manual says NOT to use an extension cord and to plug unit directly into the wall.
  • psteach1 Jul 30, 2010
    Your answer was what I thought THANKS I will not hert the frezzer as long as I use a heavey gage cord.
  • 8,197 Answers
The reason why they do not want you to use an extension cord is because most people use the wrong gage cord for the use. You can use an extension cord as long as you use the right gage wire. If you are going to use one for the Freezer then you need to use one with 12 gage wire like what is in your house.
I hope this helps you and Good Luck
Posted on Jul 30, 2010
  • Jyackle5
    Jyackle5 Jul 30, 2010
    Correct just make sure you use a heave gage cord and do not get it to long. Try to just get the length you need.
What kind of extension cord is safe to use with this freezer?
Freezer manufacturers do not recommend use of extension cords.
Jan 05, 2016 | Woods Freezers
Woods chest freezer C0501W3. Where can I get an extension cord?
LOweS,HOME DEPOT MENARDS . any good hardware ask for an appliance extension cord .
Red light on. Freezer making no noise.
freezers should never be on an extension cord . and it sounds like you might have burned the compressor up in doing so . call a local repair man or just replace the unit .
Nov 15, 2015 | Freezers
Replace burnt power cable
You can replace it with the average extension cord as most can hold up to 12 amps and your freezer will pull 2-5. Just cut the extension cord to length and cut before where the wires are burnt out. Strip wires and connect black to black, white to white and green to green. Marrett each section of wires and plug it in. If you use electrical tape to make a bundle with the Marretts afterwards that will make sure there is less of a chance the Marretts will fall off.
good luck
Apr 06, 2014 | Freezers
Parts manual for danby freezer dcf550w
I can hear it quietly cutting on and off but it doesn't get cold. I've tried turning the temperature up and down but to no avail. I've plugged it directly into a wall plug and flipped the breakers What is my next step?
Feb 01, 2013 | Danby 5.5 cu. ft. / 156 liter Chest...
The freezer is cold, but, ice is melting. Its running and the run and power lights are lit up. I removed ice(very little) around the top edge to make sure the door closes shut. It was just fine last n
All I can offer for advice is to ask if it is on an extension cord. Is the freezer plug in good shape and not blistered? Make sure that the cord is a heavy enough gauge to carry the current needed to run the compressor. An extension cord can break down over time and cause the compressor to overheat or fail. Wish I could be more help. Good luck!
May 02, 2012 | Magic Chef Chest Freezer MCCF5WBX
Used extension cord on freezer then it stopped getting cold.
never use a extension cord unless it is of a larger gauge wire size eg: #12. as opposed to standard #16 or #14. the compressor/motor will not get needed power and burns out.
Jul 12, 2010 | Frigidaire Freezers
I don't have any power...
use an extension cord and try another plug. I may also be in defrost let it set for at least 35 min to see if the defrost cycles next check your wall plug for a ground fault. I will be a little red or white button in the center of the wall plug and it pops just like a circuit breaker just push it in until it stays. good luck
Apr 21, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
29 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
