Question about HP Color LaserJet 2600n Printer
My printer does not sence the one of tonner catridges of the colors , is it the sensor
    Champion:
  • HP Expert
  • 202 Answers
Replace the toner with origional hp if problem persists then it is a serious problem but i m sure ur prob resolved by replacing the toner if u r using reffle toner
Posted on Aug 02, 2010
  • jitendra mishra
    jitendra mishra Aug 10, 2010
    if this problem persists then the lever which lock the cairtages may be broken by which this error comes.call to hp engr for the same...
    Problem Solver:
  • 5 Answers
Are you using remanufactured toners or HP OEM? If your using Remanufactured, I'm pretty sure its the chip on the toners. Try your old one and see if it will recognize that.
Posted on Jul 30, 2010
What is tonner and tonner catridge
Toner is basically ink for a laser printer or copier. The 'ink' is really a carbon powder, but it serves the same purpose.
If you want a more detailed answer, then view this page:
http://www.officemax.com/home/custom.jsp?id=m7350028
Sep 03, 2014 | Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Left side of documents print very light
this could be a problem with the tonner or the configuration of ink... in both cases try with another catridge or tonner, if the problem solves then is because the cartridge or tonner no have enough ink to print
...... if the problems persists maybe could try verifing the configuration of your printer or re instaling the printer too...
Jul 30, 2010 | HP Color Laserjet 3550 Printer
Very light print out of hp p1505 laser printer is cery light even after changing tonner and cleaning scaning unit.
This could be color miss registry, even though your printer is a monochrome printer there is a sensor which determines the color density, Black being a color, and if the sensor is damaged will cause issues like fading. Make sure you are using hp original cartridges, and if the problem is still there, contact hp for warranty options, hp's tech support line is 1800-334-51440.
Al
Eliteprintersolutions@gmail.com
Jul 11, 2010 | HP LaserJet P1505n Printer
I have a problem in my hp4700 printer.everyday morning i need to shake the tonner for getting good quality print.Iam using hp genuine tonner catridges.I changed all toners with new HP genuine.still printer...
Normally that works when toner is real low. But if you are doing that with good toner levels then it may be humidity in the room making the toner powder clump or stick.
Have you performed a clean cycle/test. You may have problems with a fuse roller but that would be a longshot thing to check for.
Mar 23, 2010 | HP LaserJet 4700 Printer
Hi i have a problem in my hp4700 printer.everyday morning i need to shake the tonner for getting good quality print.Iam using hp genuine tonner catridges
Is this and old cartridge?
Trying changing it. Use a new one.
Good Luck.
ps when I know that I'm running out of tone, that is usually what I do to get a few more pages to print,
until the new cartridge comes in. LOLl
Nov 05, 2009 | HP LaserJet 4700 Printer
Paper jam
Ohh Paper jam, so you open the printer front cover or Tonner catridge or ribbon catridge. then smothly remove the paper. its depend upon the printer.
Thanks
Aug 15, 2009 | Office Equipment & Supplies
Samsung ml-2245 toner refill problem
have a samsung ml2245 laser printer. using the printer tonner catridge refilling But Is Not Working can you have aney help me
Jun 08, 2009 | Office Equipment & Supplies
Replace tonner catridge error
Dear Sir; You fill up the cartridge that's fine,but you forget to change RF chip, it located right behind the cartridge, if you don't replace it , machine not going reset .
Jan 08, 2009 | Xerox CopyCentre C118 Copier
HP Color LaserJet 2600n Printer Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
