My washing machine is stuck on filling up with water it wont wash
Thanks mate my drain hose was too low
Posted on Apr 30, 2008
  • 145 Answers
If it keeps filling and overflows you need to check the water level switch and hose. If it keeps filling but doesn't leak out the you drain hose is too low or too far down the drain.
Posted on Apr 24, 2008
4 Suggested Answers
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
  • 11 Answers
SOURCE: washing machine wont stop filling up with water
Water valve is bypassing and need to be replaced or the water level switch control is out of order.
A remote possibily is a leaking pressure swith airhose is leaking . Good luck
Posted on Dec 28, 2008
  • 1531 Answers
SOURCE: Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Posted on Jan 31, 2010
Washing machine stopped working. The lights come on but water wont start filling
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 25, 2011 | Washing Machines
Electrolux ewf1282 wont fill with water
heatman101
Jul 10, 2011 | Washing Machines
Wont fill with water!!!!!
heatman101
Apr 26, 2011 | Washing Machines
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Feb 23, 2011 | Washing Machines
Why wont the washer start filling ?
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Water is filling up in the machine when not in use
You have dirt stuck in the soleniod valve... kinda the opposite problem of these tips...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stuck on wash n wont spin not filling up with water
If water is coming into your machine but not filling up then you have a siponing problem (draining and filling at the same time). Raise the drain hose up higher at the drain at the back of your machine.
Jul 09, 2010 | GE WBSR3140DW Top Load Washer
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Washer wont stop filling even when its washing. GE
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Jun 29, 2009 | Washing Machines
Samsung Silver Care washing machine
Sounds like your inlet valve is stuck Open ( meaning it wont shut off incoming water ) That may be defective or the control to it may be at fault.. Try unplugging the washer ..and see if the water still continues to fill up the drum? If that happens, then your valve is probably in need of replacement.. Typically, when de-energized..they close and stop water from entering the system.. Hope that helps
Aug 18, 2008 | Washing Machines
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
