Question about Hayward GO-KIT #2 HAYWARD SUPER II PUMP SERIES SP-3000 & SP-30
Pump starts but then trips breaker ? - Hayward GO-KIT #2 HAYWARD SUPER II PUMP SERIES SP-3000 & SP-30
    President:
  • 2,702 Answers
The pump motor has a short in it its pulling far to many amps thats why the trip pops out
Posted on Jul 30, 2010
Why does my Pool pump and boaster pump on Timer (T104) trips breaker?
check your wiring sounds like something isnt correct
Oct 16, 2014 | Pool & Spa
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
GFI breaker tripping
It could be a faulty pump,
rusty pump & moisture on copper windings leaks active, neutral back to earth on your pump & trips your breaker.
Solution: Replace pump.
Aug 21, 2013 | Fisher and Paykel Washing Machines
Not pumping...not tripping breaker...making an electrical noise like it is trying to start.. a buzzing noise for a few seconds and then stops without tripping breaker...turned off breaker...
Remove pump and check for something stuck in the impellor assuming that it has one. You didn't say what you are working with. So, sounds like something clogged or stuck in what ever it is that you are pumping. If that is not the case then you have a bad pump motor.
Jun 30, 2009 | Plumbing
Polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
May 29, 2009 | Polaris Pb4 - 60 Booster Pump
Pump trips breaker
If the seals are damaged, water will leak into motor section and cause GFI to trip and yet the pump will seem that it is running fine if plugged into a non-GFI receptacle
May 28, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Trips breaker, windings not open, no continuity from windings to frame. startsfor split second then trips breaker. Breaker is ok
ASSUMING THIS IS SINGLE PHASE HAVE YOU CHECKED THE CAPACITORS. START CAPACITOR COULD BE BAD OR BURNT LEAD. HAVE YOU MADE SURE THE PUMP IS NOT LOCKING UP. POINTS IN THE PRESSURE SWITCH LOOK GOOD. HOPE THIS HELPS, JODY
Apr 26, 2009 | Plumbing
Hayward GO-KIT #2 HAYWARD SUPER II PUMP SERIES SP-3000 & SP-30 Logo
344 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
