Question about LG 32LG30 32 in. LCD HDTV
Remote will not turn off TV nor change channels model 32LB9D LG TV
    President:
  • 1,099 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote. Thats it, I hope you got it going again?
Posted on Jul 30, 2010
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
I have the language set up but I cannot receive the captions. How do I do this?
try going to onscreen menu , scroll around till you find a caption option and turn it on
some remotes for the tv will have that option in a button
Sep 17, 2016 | LG LCD TV Remote Control MKJ39927802...
Lg 32lb9d remote wont program to tv
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 28, 2015 | LG LCD TV Remote Control 6710900011Z...
Lg volume problems
The contacts between the carbon of remote and the rubberized button could be faulty.
Jul 19, 2014 | LG LCD TV Remote Control MKJ39927802...
LG 32LB9D lost channels
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 16, 2017 | LG 32LB9D TV
I have an LG 32LB9D TV and had been having p[roblems with it getting channel 73 (7mate) and 90 (GEM). I could get a good picture on both but no sound. Now all of the sudden it won't scan for channels, it...
Hello, My sister had the same problem, contacted LG, they wanted, the serial number, model number, and sent a usb with up-dated software, she plugged it in at the side of the tv, and it worked.Please contact them yourself, sure you will, get the help you need. Regards, Joni
Oct 30, 2010 | LG 32LB9D TV
Screen is black even though the green light is lit
Tv has power supply board inside defective. This board needs replaced.
Aug 18, 2009 | LG 32LB9D TV
Jerry G.
Apr 10, 2009 | LG 32LB9D TV
LG 32LB9D is not picking up all channels
You must have the tuning band set to Cable not Air. From the video menu choose cable, you may have to options for cable, try both.
Let me know if this helps.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 09, 2009 | LG 32LB9D TV
LG 32LG30 32 in. LCD HDTV Logo
232 people viewed this question
