Question about Sharp CD-SW200 CD Shelf System
Everytime i turn my volume up too 17 the entire system would shut off
Had the same problem. Timer light would blink and system would shut off. It turned out to be the speaker wires going to one speaker were touching each other. The wire had become pinched and it made a bare spot where the wires made a little contact with each other. I cut the wires and spliced them back together and have not had any problems since.
Posted on Sep 24, 2010
Everytime I turn a corner or go over a bump the entire system shuts off and reboots. It will do this mutliple times, to the point where its no longer playing music anymore. What's wrong with it?
I would check fusable link on power supply 12 volt DC from battery voltage. if compression springs loose inside link, possible that bumps are causing loss of contact causing power down, then when the reconnect, you get reboot, check entire power supply line from point of power connection to unit.
DW Mylin
Nov 28, 2012 | Kenwood Kdc-138 Car Cd Receiver Aux Ipod...
Everytime I try to change the volume on my samsung it says "not available" in the middle of my screen. How should I fix this? Also I just had white spots on my tv and the technician came and...
Hello... Your TV speakers are turned off. If you don't have a sound bar or a surround sound system, go into the TV menu, audio, speaker settings and turn them on. If you have a sound bar or surround sound system, use the remote for that system to adjust the volume. I hope this helps!
Nov 25, 2017 | Samsung 46 in. Flat-Panel LCD HDTV
My su g90 shuts off when i turn it up loud what do
Amplifiers get hot. The more you crank the volume up (or use extended for extended periods), the more current is required. When it gets hot, there is a fan motor (on the back), that should turn on. I believe your fan motor (brush) is worn out and therefore non-functional. Under this condition when the system overheats, it automatically changes mode to protect circuits.
Also note: if it works when you initially turn it on (cold) for a few minutes it should work fine...until it starts getting hot inside the case.
Oct 20, 2009 | Technics Audio Players & Recorders
System shuts down when playing music dvds at 17 or 18
Check your speakers one by one, maybe one of them are about to burn that´s the reason your device turn on protection state,good luck
Mar 16, 2009 | Televison & Video
Volume is too loud
change the function to cd or aux before you turn it off and then change the volume before going to your preferred function. It is the only way around it.
Mar 16, 2009 | GPX HM3817DT Shelf System
MY HP PAVILION DV9000 ENTERTAINMENT LAPTOP KEEPS reseting with
oh no, i hate to say this but, you have contracted a serious virus. you will have to grab the recovery disk and insert it. shut the laptop down and unplug for 3 min then, restart and restore the entire unit. do not repair. you will need to totally restore the complete OS. clear all partition's. if you click the repair option, the virus will remain on the partitioned drive.
Mar 04, 2009 | HP Pavilion dv9000t 17" Notebook Laptop PC...
Gemsound power amplifier exa3955 keeps shutting off.
it is most likely that the shutting off is an precautionary system response to protect your amp and drivers. check all connections again for wrong polarity.
Feb 01, 2009 | Audio Players & Recorders
UV7I Volume Control Problem
they all do that ive tried you just have to deal with it it sucks but life goes on wright wright
Dec 17, 2008 | Jensen VM9510 Car DVD Player
Shuts down at moderate volume
change the impeadence settings of the receiver page 25 of the manual will tell you how.
Dec 26, 2007 | Yamaha RX-V661 Receiver
Sharp CD-SW200 CD Shelf System Logo
94 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
