Access 2000 database won't compact and repair.
My access database has reached the 2 GB limit and will no longer compact and repair. It is a major database for our company and we will be out of business without it. Is there any way to repair this?
Thanks
    New Friend:
  • 3 Answers
User friendly interface which allows technical as well as non-technical users to easily work with the tool. The software is capable to restore queries, reports, forms, tables, macros and all other object of access database (.accdb or .mdb) file.
Go through Access File Recovery
Posted on Mar 21, 2016
    Champion:
  • 401 Answers
It must be access database corrupted, make use Access Repair Toolbox software supports ms access databases starting with MS Access 97 version program
Posted on Jun 23, 2012
    Problem Solver:
  • 17 Answers
Mchampion,
You are in luck. I had the same problem a while back. Most of the time you will not be able to compact and repair a database that has reached capacity, however, you can import the database into a new one. The first thing you are going to have to do is find a very large table in your database and copy it into a new one. Then, delete that table from your old database. Now, open another new database. Go to the file menu and choose import. Now you must find your database in the directory and click it. Now choose one of the given options (tables, queries, etc.). Then, Press control + a to select all items. Now hit okay and it will import all of the items from your old database from that section into the new one. You must do this for each section (tables, queries, etc.). When everything is imported (should take less than an hour), compact and repar the new database. This will give you additional space to work with. Now you can bring in the table that you copied into a new database earlier the same way (import). This should put you back in business.
I suggest creating a 2nd database for any other data you may want to add later. You can always make link tables and such in your old database in order to get the additional data and prevent crashing your old database.
Let me know if you need any additional help.
ArthurB
Posted on Apr 24, 2008
Database corrupted
You can use Recovery Toolbox for Access is used for recovering data from corrupted Microsoft Access database files with *.mdb, *.accdb extensions.
For more: https://recoverytoolbox.com/repair_access.html
Oct 29, 2015 | Microsoft Office Computers & Internet
I need to perform access database repair
The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
1. Do not Open Access database must closed
2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
3. Close the .mdb file related to .ldb file before you delete the .ldb file.
4. Then Run the Compact and Repair tool
Read more about Access Repair Toolbox
On:- http://www.access.repairtoolbox.com/
I tried lots of the suggestions and eventually found that this page was the most helpful http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/1385-%E2%80%8Bhardly-corrupted-access-2007-database
Feb 28, 2015 | Microsoft Office Access 2007 for PC
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Feb 23, 2015 | Microsoft Access 2003 for PC
MS Access database recovery
Have you tried creating a NEW MDB, and then IMPORTING the objects from the Crashed/Corrupted MDB?
This will SOMETIMES serve to rescue most if not all of the corrupted entities .
Or:
You can try:
eRepair Access is a powerful Access database recovery solution for damaged *.mdb and *.accdb files created in Access 2000 and above. Having such a tool at hand immediately after a database file corruption incident may save you a great deal of time, nerve and, of course, an ample amount of money that would otherwise be paid to third-party recovery services. With eRepair Access, you don't need to depend on anyone and entrust your Access data (often quite sensitive) into somebody else's hands. You don't have to wait. You don't have to call it a day knowing that the damaged Access file will not be restored (if at all) until tomorrow. With eRepair Access, you can be back in the game within minutes!
For more information: http://access.erepairtools.com/
If doesn't help, look here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/933-ms-access-database-recovery
Feb 05, 2015 | Microsoft Office Professional 2007 Full...
Access 2007 corrupted database
You may try this third party tool programmed with best technology the tool support all windows and MS office versions. You may try free demo version of this software to preview your recovered access database. SysTools Access Recovery you may check How tool works and its user friendly interface make this easy to handle.
Jan 11, 2015 | Microsoft Office Professional 2007 Full...
Need guidance to restore mdb file from Access
Here is a link http://www.en.accessrecovery.org and http://www.compactaccessdatabase.net on the same particular problem that I resolved effectively using this tool. This tool is smartly programmed and allow to restore database from a corrupt database table without hassle.
Apr 11, 2014 | Computers & Internet
How can i repair a damaged access database
There are some reasons which may damage your MS access database such as virus infection, software crash, accidental shutdown of system, unrecognized format of database, corruption of storage media etc. These issues are easy to overcome by using third party software of access database repair.you can try Kernel Access Database Recovery Software one of the best software in Data Recovery
For information you can visit here ...http://www.accessrecoverytool.net
Aug 23, 2010 | Microsoft Computers & Internet
MS Access 2007 freezes when opening a basic TABLE. Please assist in resolving this frustrating problem.
You might try the "Compact and Repair" database option first before working on the database. Click on the "Office Button", then click on "Manage", then select "Compact and Repair Database". The usage dialog from there is straightforward. One that'srun, try opening the database again and opening the table as well.
Jul 15, 2009 | Microsoft Office Standard for PC
Microsoft Access 2003 crashes on ''Compact and Repair''
Your best bet would be to repair your office installation in Vista. Regards -- Joe (Access VBA Examples)
Nov 10, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
702 people viewed this question
David Payne
David Payne
