Question about PfaFF Sewing Machines
Top tension will tighten while sewing and won't loosen unless I untread the machine pfaff expression 2048
  • PfaFF Master
  • 7,365 Answers
Have you checked for thread fragments in the area
Posted on Jul 31, 2010
Top tension issues with a Pfaff quilt expression 4.2 bubbles in back.Was sewing and then didn't sound normal.How do I fix this?
FWIW, thread messes under the fabric are usually a top thread issue.
Make sure you are using a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct,.
Mar 21, 2018 | PfaFF Sewing Machines
I have a pfaff expression 4.0 and can’t find how to change the tension
This machine has an electronic thread tension control. You'll only be able to adjust the tension for the current stitch, until you turn off the machine or change your stitch selection. Press the Setting button and use the Up/Down arrows on the wheel to get the move the setting selection box on the Thread tension line, if needed. Use the Left/Right arrows on the wheel to increase or decrease the tension. Press OK (the center of the wheel) to save this tension. Test the tension on a scrap of your project and repeat the steps until the thread tension is appropriate for the project. Press Info when in the sewing mode to see the current thread tension.
The manual for the Pfaff Quilt Expression 4.0 (and a couple of other models in the Expression line) is available from Pfaff here: http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/expression_2_3_4-manual-EN.pdf?ext=.pdf . See page 2:16 (page 28 of the PDF) for the details. Pages 2:10-2:11 show the buttons for the Expression 4.0.
I hope this helps.
Jan 28, 2018 | PfaFF Sewing Machines
Pfaff expression thread broke half way through button hole. How do I complete the buttonhole?
1. Change thread/needle.
2. If the bottom stitch is loose then tighten the top tension. If the bottom appears to be too tight then loosen the top tension.
3. It may help to put the feed dogs down also.
Dec 21, 2017 | PfaFF Sewing Machines
Having a problem with bobbin thread showing through while trying to embroider on my pfaff 7570
Usually, slightly tightening the bobbin thread, and/or loosening the top thread solves this problem. Make sure there is no fluff in the bobbin area, clean and oil regularly. Experiment with these tension adjustments and make a note of what you did and what works.
Feb 27, 2017 | PfaFF Sewing Machines
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
Can i oil; my own sewing machine..quilt expressions 2048 pfaff
you will have to contact pfaff customer service about the oiling of the machine, cause from what I've learned, some machines have to oiled by a repair technican.
May 16, 2012 | PfaFF Sewing Machines
How to adjust lower tension on pfaff hobby 370
On the bobbin case is a screw. Mark the case with a tiny dab of nail polish and the edge of the screw. This will tell you where you began.
Turn the screw: right to tighten and left to loosen.
This is an adjustment that is usually not needed unless you are changing the weight of the thread being used on the bobbin.
Mar 12, 2010 | PfaFF Sewing Machines
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
79 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
