Tv set switches off by itself after 5 minutes
The tv set starts up and works normaly,but after 5 minutes more or less switches off.If I turn it on again right after,it runs for almost the same time before and switches off again.I've checked for cold solders,but I've not found
anything wrong.Could you tell the possible causes for this malfunction?
I appreciate any help I get.
  • alien1 May 03, 2008
    Thanks Doctor video for your tip.The tv set now presents a new malfuction which is:as soon as it starts turns off and the flyback
    transformer is arcing near the HOT.I think the flyback has a defectiveness ,that's almost 100% sure. I decided to replace it and see what happens.I've already ordered it and I'm waiting for it.If that solves the problem,I'll let you know.
    Thanks!
    Alien1
  • alien1 May 18, 2008
    The solution for the malfunction was the substitution of flyback.Thanks to those who tried to help me.
    Scholar:
  • 131 Answers
I would need model number on back to give you more exact solution. but it sounds like the voltage reulator is bad .you could get a hair dryer and put it on heat and go over board and when tv shut off that is the problem with freeze bottle you could get at radio shack you go over parts will keep it on longer good luck
thanks jay DOCTOR VIDEO
Posted on Apr 25, 2008
Child lock came on by itself on apex pf2720
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Aug 15, 2012 | Apex Digital PF2720 27" TV
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
TV turns itself off.
the power off is power suply problem. has static noise? some small electric internal discharge normaly once occur, has this kind of malfuntion. my advice is send to repair, normaly is HV Circuirt (Board) has lost Isolation, needs to be replaced
Feb 20, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Clapper goes off every few minutes with no stimulus to do so
While in the Away setting, the clapper will turn on when it detects any noise over a specific threshold. After ten minutes of inactivity, it will turn off. This setting is meant as way turn on the lights as soon as you walk in the door or to startle might be intruders. If you slide the switch to Lo or Hi mode, the clapper will respond to your claps or any loud noises that sound similar. Hi is high sensitivity, for quieter rooms; Lo is low sensitivity, for louder areas.
Jan 27, 2009 | As Seen On TV Clapper Plus
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
